Peerless by Tymphany 835026 8" Aluminum Cone HDS Woofer
Brand:|Model: 835026|Part # 264-1100
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments.
List Price$127.99
You Save25%
$95.67
Buy 4+$87.53
Part # 264-1100
  • Truncated cast aluminum frame
  • Aluminum cone with half-roll rubber surround
  • 1-1/2" diameter long-throw voice coil
  • Shorting rings for reduced distortion
  • Under-spider and voice coil ventilation
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments. A powerful ferrite magnet system is coupled to a finite element analysis-designed suspension system, containing a linear spider design and rubber surround. The motor incorporates an aluminum shorting ring that reduces coil inductance, extending frequency response performance and reducing second harmonic distortion. A cast aluminum basket provides high structural rigidity, heat-sinking capacity for the motor, and additional ventilation under the spider that in combination with a vented cone neck reduces air compression effects. The aluminum cone combines high strength with low moving mass, offering superb transient response and sharp definition.
  • Nominal Diameter8"
  • Power Handling (RMS)75 Watts
  • Power Handling (max)150 Watts
  • Impedance8 ohms
  • Frequency Response20 to 3,000 Hz
  • Sensitivity86.8 dB 2.83V/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)27 Hz
  • DC Resistance (Re)5.5 ohms
  • Voice Coil Inductance (Le)0.57 mH
  • Mechanical Q (Qms)4.3
  • Electromagnetic Q (Qes)0.46
  • Total Q (Qts)0.41
  • Compliance Equivalent Volume (Vas)2.33 ft.³
  • Mechanical Compliance of Suspension (Cms)0.87 mm/N
  • BL Product (BL)8.96 Tm
  • Diaphragm Mass Inc. Airload (Mms)38.57g
  • Maximum Linear Excursion (Xmax)6.02 mm
  • Surface Area of Cone (Sd)232.4 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.86"
  • Baffle Cutout Diameter7.5"
  • Depth4.27"
  • # Mounting Holes6
  • Sealed Volume0.65 ft.³
  • Sealed F356 Hz
  • Vented Volume1.94 ft.³
  • Vented F331 Hz
  • BrandPeerless by Tymphany
  • Model835026
  • Part Number264-1100
  • UPC844632084119
  • Product CategoryWoofers
    (1 Reviews)
  • Weight5.4 lbs.
View similar products to the Peerless by Tymphany 835026 8" Aluminum Cone HDS Woofer
