Peerless by Tymphany 835025 6-1/2" Aluminum Cone HDS Woofer
Brand:|Model: 835025|Part # 264-1086
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments.
List Price$99.99
You Save25%
$75.47
Buy 4+$69.05
Part # 264-1086
  • Truncated cast aluminum frame
  • Aluminum cone with half-roll rubber surround
  • Long-throw voice coil
  • Shorting rings for reduced distortion
  • Under-spider and voice coil ventilation
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments. A powerful ferrite magnet system is coupled to a finite element analysis-designed suspension system, containing a linear spider design and rubber surround. The motor incorporates an aluminum shorting ring that reduces coil inductance, extending frequency response performance and reducing second harmonic distortion. A cast aluminum basket provides high structural rigidity, heat-sinking capacity for the motor, and additional ventilation under the spider that in combination with a vented cone neck reduces air compression effects. The aluminum cone combines high strength with low moving mass, offering superb transient response and sharp definition.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)55 Watts
  • Power Handling (max)110 Watts
  • Impedance8 ohms
  • Frequency Response20 to 3,000 Hz
  • Sensitivity87.2 dB 2.83V/1m
  • Voice Coil Diameter1.25"
  • Resonant Frequency (Fs)38 Hz
  • DC Resistance (Re)6.3 ohms
  • Voice Coil Inductance (Le)0.39 mH
  • Mechanical Q (Qms)3.3
  • Electromagnetic Q (Qes)0.42
  • Total Q (Qts)0.37
  • Compliance Equivalent Volume (Vas)0.87 ft.³
  • Mechanical Compliance of Suspension (Cms)0.86 mm/N
  • BL Product (BL)8.58 Tm
  • Diaphragm Mass Inc. Airload (Mms)20.13g
  • Maximum Linear Excursion (Xmax)5.39 mm
  • Surface Area of Cone (Sd)143.1 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter7.18"
  • Baffle Cutout Diameter5.75"
  • Depth3.47"
  • # Mounting Holes6
  • Sealed Volume0.23 ft.³
  • Sealed F381 Hz
  • Vented Volume0.67 ft.³
  • Vented F345 Hz
  • BrandPeerless by Tymphany
  • Model835025
  • Part Number264-1086
  • UPC844632084041
  • Product CategoryWoofers
    (4 Reviews)
  • Weight3.1 lbs.
View similar products to the Peerless by Tymphany 835025 6-1/2" Aluminum Cone HDS Woofer
