Peerless by Tymphany 835024 5-1/4" Aluminum Cone HDS Woofer
Brand:|Model: 835024|Part # 264-1076
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments.
List Price$71.99
Regular Price$53.67
You Save48%
Sale Price
$28.00
Part # 264-1076
  • Truncated cast aluminum frame
  • Aluminum cone with half-roll rubber surround
  • Long-throw voice coil
  • Shorting rings for reduced distortion
  • Under-spider and voice coil ventilation
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments. A powerful ferrite magnet system is coupled to a finite element analysis-designed suspension system, containing a linear spider design and rubber surround. The motor incorporates an aluminum shorting ring that reduces coil inductance, extending frequency response performance and reducing second harmonic distortion. A cast aluminum basket provides high structural rigidity, heat-sinking capacity for the motor, and additional ventilation under the spider that in combination with a vented cone neck reduces air compression effects. The aluminum cone combines high strength with low moving mass, offering superb transient response and sharp definition.
  • Nominal Diameter5-1/4"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance8 ohms
  • Frequency Response50 to 5,000 Hz
  • Sensitivity86.1 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)72 Hz
  • DC Resistance (Re)5.9 ohms
  • Voice Coil Inductance (Le)0.24 mH
  • Mechanical Q (Qms)3.18
  • Electromagnetic Q (Qes)0.82
  • Total Q (Qts)0.65
  • Compliance Equivalent Volume (Vas)0.19 ft.³
  • Mechanical Compliance of Suspension (Cms)0.46 mm/N
  • BL Product (BL)5.88 Tm
  • Diaphragm Mass Inc. Airload (Mms)10.6g
  • Maximum Linear Excursion (Xmax)3.5 mm
  • Surface Area of Cone (Sd)91.6 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.99, across flats 5.28"
  • Baffle Cutout Diameter4.75"
  • Depth2.77"
  • Bolt Circle Diameter5.51"
  • # Mounting Holes6
  • Sealed Volume0.24 ft.³
  • Sealed F395 Hz
  • Vented Volume0.49 ft.³
  • Vented F348 Hz
  • BrandPeerless by Tymphany
  • Model835024
  • Part Number264-1076
  • UPC844632083990
  • Product CategoryWoofers
    (1 Reviews)
  • Weight2.5 lbs.
View similar products to the Peerless by Tymphany 835024 5-1/4" Aluminum Cone HDS Woofer
