Peerless by Tymphany 830992 4" GFC Cone HDS Woofer
Brand:|Model: 830992|Part # 264-1066
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments.
List Price$50.99
You Save17%
$42.17
Buy 4+$38.57
Part # 264-1066
  • Truncated cast aluminum frame
  • Glass-Fibre Composite (GFC) cone with half-roll rubber surround
  • Long-throw voice coil
  • Shorting rings for reduced distortion
  • Under-spider and voice coil ventilation
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments. A powerful ferrite magnet system is coupled to a finite element analysis-designed suspension system, containing a linear spider design and rubber surround. The motor incorporates an aluminum shorting ring that reduces coil inductance, extending frequency response performance and reducing second harmonic distortion. A cast aluminum basket provides high structural rigidity, heat-sinking capacity for the motor, and additional ventilation under the spider that in combination with a vented cone neck reduces air compression effects. The Glass-Fibre Composite (GFC) cone combines high strength with low moving mass, offering superb transient response and sharp definition.
  • Nominal Diameter4"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance8 ohms
  • Frequency Response85 to 5,000 Hz
  • Sensitivity85.9 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)89 Hz
  • DC Resistance (Re)5.3 ohms
  • Voice Coil Inductance (Le)0.24 mH
  • Mechanical Q (Qms)2.95
  • Electromagnetic Q (Qes)0.72
  • Total Q (Qts)0.58
  • Compliance Equivalent Volume (Vas)0.09 ft.³
  • Mechanical Compliance of Suspension (Cms)0.55 mm/N
  • BL Product (BL)4.91 Tm
  • Diaphragm Mass Inc. Airload (Mms)5.9g
  • Maximum Linear Excursion (Xmax)3 mm
  • Surface Area of Cone (Sd)56.1 cm²
  • Cone MaterialFiberglass
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter4.76"
  • Baffle Cutout Diameter4"
  • Depth2.51"
  • # Mounting Holes6
  • Sealed Volume0.07 ft.³
  • Sealed F3131 Hz
  • Vented Volume0.18 ft.³
  • Vented F364 Hz
  • BrandPeerless by Tymphany
  • Model830992
  • Part Number264-1066
  • UPC844632083945
  • Product CategoryWoofers
    (1 Reviews)
  • Weight2.15 lbs.
View similar products to the Peerless by Tymphany 830992 4" GFC Cone HDS Woofer
