Peerless by Tymphany 830990 6-1/2" GFC Cone HDS Woofer
Brand:|Model: 830990|Part # 264-1084
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments.
List Price$83.99
You Save26%
$62.47
Buy 4+$57.15
Part # 264-1084
  • Truncated cast aluminum frame
  • Glass-Fibre Composite (GFC) cone with half-roll rubber surround
  • Long-throw voice coil
  • Shorting rings for reduced distortion
  • Under-spider and voice coil ventilation
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments. A powerful ferrite magnet system is coupled to a finite element analysis-designed suspension system, containing a linear spider design and rubber surround. The motor incorporates an aluminum shorting ring that reduces coil inductance, extending frequency response performance and reducing second harmonic distortion. A cast aluminum basket provides high structural rigidity, heat-sinking capacity for the motor, and additional ventilation under the spider that in combination with a vented cone neck reduces air compression effects. The Glass-Fibre Composite (GFC) cone offers a unique acoustic and visual experience.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)50 Watts
  • Power Handling (max)100 Watts
  • Impedance8 ohms
  • Frequency Response20 to 3,000 Hz
  • Sensitivity88.4 dB 2.83V/1m
  • Voice Coil Diameter1.25"
  • Resonant Frequency (Fs)46 Hz
  • DC Resistance (Re)6.2 ohms
  • Voice Coil Inductance (Le)0.42 mH
  • Mechanical Q (Qms)3.1
  • Electromagnetic Q (Qes)0.44
  • Total Q (Qts)0.39
  • Compliance Equivalent Volume (Vas)0.71 ft.³
  • Mechanical Compliance of Suspension (Cms)0.7 mm/N
  • BL Product (BL)8.32 Tm
  • Diaphragm Mass Inc. Airload (Mms)16.97g
  • Maximum Linear Excursion (Xmax)5.34 mm
  • Surface Area of Cone (Sd)143.1 cm²
  • Cone MaterialFiberglass
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.69"
  • Baffle Cutout Diameter5.75"
  • Depth3.47"
  • # Mounting Holes6
  • Sealed Volume0.17 ft.³
  • Sealed F3101 Hz
  • Vented Volume0.5 ft.³
  • Vented F356 Hz
  • BrandPeerless by Tymphany
  • Model830990
  • Part Number264-1084
  • UPC844632084034
  • Product CategoryWoofers
    (6 Reviews)
  • Weight3.65 lbs.
View similar products to the Peerless by Tymphany 830990 6-1/2" GFC Cone HDS Woofer
