Peerless by Tymphany 830946 6-1/2" Paper Cone Woofer Speaker 4 Ohm
Brand:|Model: 830946|Part # 264-1148
The Peerless SLS Series 830946 6-1/2" woofer is a versatile, solidly-performing choice for midbass, woofer, or subwoofer applications.
List Price$78.99
You Save25%
$59.21
Buy 4+$54.17
Part # 264-1148
  • Works great as a subwoofer in compact systems
  • Sculpted and vented stamped steel frame promotes motor cooling
  • Powerful ceramic magnet system with bumped back plate for full excursion
  • Coated paper cone with oversized half-roll rubber surround
  • Long-throw 1-1/2" voice coil
  • Aluminum shorting ring in magnetic gap reduces distortion
  • 4 ohm nominal impedance
A new addition to the SLS Series of speakers, the Peerless 830946 6-1/2" woofer features a paper cone, wide rubber half-roll surround, and hefty ceramic ferrite magnet with distortion-reducing aluminum shorting ring. Audio is reproduced with accuracy and detail.
The speaker's distinctively sculpted truncated steel frame facilitates close driver spacing or a narrower mounting baffle, and its extensive under-spider venting promotes voice coil cooling for reduced power compression and improved long term reliability. The 830946 will perform superbly as a dedicated low-mid bass driver, as well as delivering solid output when used as a compact subwoofer.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)75 Watts
  • Power Handling (max)150 Watts
  • Impedance4 ohms
  • Frequency Response20 to 1,000 Hz
  • Sensitivity82 dB 1W/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)42 Hz
  • DC Resistance (Re)2.7 ohms
  • Voice Coil Inductance (Le)0.65 mH
  • Mechanical Q (Qms)4.92
  • Electromagnetic Q (Qes)0.38
  • Total Q (Qts)0.35
  • Compliance Equivalent Volume (Vas)0.4 ft.³
  • Mechanical Compliance of Suspension (Cms)0.47 mm/N
  • BL Product (BL)7.6 Tm
  • Diaphragm Mass Inc. Airload (Mms)30.5g
  • Maximum Linear Excursion (Xmax)8.2 mm
  • Surface Area of Cone (Sd)123.5 cm²
  • Cone MaterialPaper
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.46 across flats, 7.165"
  • Baffle Cutout Diameter5.79"
  • Depth3.28"
  • Bolt Circle Diameter6.67"
  • # Mounting Holes6
  • Sealed Volume0.09 ft.³
  • Sealed F395 Hz
  • Vented Volume0.21 ft.³
  • Vented F355 Hz
  • BrandPeerless by Tymphany
  • Model830946
  • Part Number264-1148
  • UPC844632092688
  • Product CategoryWoofers
    (3 Reviews)
  • Weight5.55 lbs.
View similar products to the Peerless by Tymphany 830946 6-1/2" Paper Cone Woofer Speaker 4 Ohm
