Peerless by Tymphany 830883 6-1/2" Nomex Cone HDS Woofer
Brand:|Model: 830883|Part # 264-1094
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments.
List Price$105.99
You Save18%
$87.05
Buy 4+$79.63
Part # 264-1094
  • Peerless HDS Exclusive Series
  • Cast aluminum frame
  • Nomex cone with half-roll rubber surround
  • Long-throw voice coil
  • Shorting rings for reduced distortion
  • Under-spider and voice coil ventilation
  • Aluminum phase plug improves off-axis linearity
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments. A powerful ferrite magnet system is coupled to a finite element analysis-designed suspension system, containing a linear spider design and rubber surround. The motor incorporates an aluminum shorting ring that reduces coil inductance, extending frequency response performance and reducing second harmonic distortion. A cast aluminum basket provides high structural rigidity, heat-sinking capacity for the motor, and additional ventilation under the spider that in combination with a vented cone neck reduces air compression effects. The famous Peerless Nomex cone offers neutral, accurate audio reproduction.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance8 ohms
  • Frequency Response40 to 3,000 Hz
  • Sensitivity87.2 dB 2.83V/1m
  • Voice Coil Diameter1.25"
  • Resonant Frequency (Fs)43 Hz
  • DC Resistance (Re)5.9 ohms
  • Voice Coil Inductance (Le)0.18 mH
  • Mechanical Q (Qms)2.2
  • Electromagnetic Q (Qes)0.46
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)0.81 ft.³
  • Mechanical Compliance of Suspension (Cms)0.8 mm/N
  • BL Product (BL)7.7 Tm
  • Diaphragm Mass Inc. Airload (Mms)17.34g
  • Maximum Linear Excursion (Xmax)5.62 mm
  • Surface Area of Cone (Sd)143.1 cm²
  • Cone MaterialNomex
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter7.09"
  • Baffle Cutout Diameter5.75"
  • Depth3.43"
  • # Mounting Holes6
  • Sealed Volume0.15 ft.³
  • Sealed F3100 Hz
  • Vented Volume0.41 ft.³
  • Vented F358 Hz
  • BrandPeerless by Tymphany
  • Model830883
  • Part Number264-1094
  • UPC844632084089
  • Product CategoryWoofers
    (2 Reviews)
  • Weight3.85 lbs.
View similar products to the Peerless by Tymphany 830883 6-1/2" Nomex Cone HDS Woofer
