Peerless by Tymphany 830878 3-1/2" Passive Radiator
Brand:|Model: 830878|Part # 264-1060
A useful alternative to overlong ports, passive radiators like the Peerless 830878 offer designers a well-proven method of extending and enhancing bass response.
List Price$15.99
You Save31%
Buy 4+$10.00
Part # 264-1060
  • Coated paper cone with rubber surround
  • Low resonance frequency for deepest possible bass
  • Cosmetic surface mount steel frame matches Peerless SDS series
  • Straight-sided frame fits into narrow enclosures and permits tight spacing
  • Compatible with small woofers by Peerless and others
The Peerless 830878 3-1/2" passive radiator is a cosmetic and performance complement to the Peerless SDS Series woofers. Its attractive stamped steel frame, coated paper cone, and rubber surround are visual and performance matches with the Peerless speaker drivers. Passive radiators are a viable alternative to ports whenever duct length exceeds available enclosure space. May be used in multiples to achieve desired performance.
Specifications: • Fs: 29 Hz • Vas: 0.10 cu. ft. • Cms: 791 um/N • Mms: 38.5 g • Rms: 0.48 kg/s • Sd: 50.2 sq. cm. • Dimensions: Outside diameter: 4.85", 4.14" across flats, Cutout diameter: 3.64", Depth: 1.35".
  • Nominal Diameter3-1/2"
  • BrandPeerless by Tymphany
  • Model830878
  • Part Number264-1060
  • UPC844632083914
  • Product CategoryPassive Radiators
    (3 Reviews)
  • Weight0.3 lbs.
View similar products to the Peerless by Tymphany 830878 3-1/2" Passive Radiator
in the Passive Radiators product category.
