Peerless by Tymphany 830875 6-1/2" Nomex Cone HDS Woofer
Brand:|Model: 830875|Part # 264-1092
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments.
List Price$76.99
You Save22%
$59.90
Buy 4+$57.75
Part # 264-1092
  • Truncated cast aluminum frame
  • Nomex cone with half-roll rubber surround
  • Long-throw voice coil
  • Shorting rings for reduced distortion
  • Under-spider and voice coil ventilation
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments. A powerful ferrite magnet system is coupled to a finite element analysis-designed suspension system, containing a linear spider design and rubber surround. The motor incorporates an aluminum shorting ring that reduces coil inductance, extending frequency response performance and reducing second harmonic distortion. A cast aluminum basket provides high structural rigidity, heat-sinking capacity for the motor, and additional ventilation under the spider that in combination with a vented cone neck reduces air compression effects. The famous Peerless Nomex cone offers neutral, accurate audio reproduction.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)75 Watts
  • Power Handling (max)100 Watts
  • Impedance8 ohms
  • Frequency Response40 to 3,000 Hz
  • Sensitivity89.5 dB 2.83V/1m
  • Voice Coil Diameter1.25"
  • Resonant Frequency (Fs)46 Hz
  • DC Resistance (Re)7.18 ohms
  • Voice Coil Inductance (Le)0.41 mH
  • Mechanical Q (Qms)3.2
  • Electromagnetic Q (Qes)0.41
  • Total Q (Qts)0.36
  • Mechanical Compliance of Suspension (Cms)0.76 mm/N
  • BL Product (BL)8.95 Tm
  • Diaphragm Mass Inc. Airload (Mms)15.9g
  • Maximum Linear Excursion (Xmax)5.3 mm
  • Surface Area of Cone (Sd)143.1 cm²
  • Cone MaterialNomex
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter7.17"
  • Baffle Cutout Diameter5.75"
  • Depth3.27"
  • # Mounting Holes6
  • Sealed Volume0.15 ft.³
  • Sealed F3105 Hz
  • Vented Volume0.44 ft.³
  • Vented F359 Hz
  • BrandPeerless by Tymphany
  • Model830875
  • Part Number264-1092
  • UPC844632084072
  • Product CategoryWoofers
    (8 Reviews)
  • Weight3.65 lbs.
View similar products to the Peerless by Tymphany 830875 6-1/2" Nomex Cone HDS Woofer
