Peerless by Tymphany 830874 6-1/2" PPB Cone HDS Woofer
Brand:|Model: 830874|Part # 264-1090
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments.
List Price$74.99
You Save29%
$53.45
Buy 4+$48.89
Part # 264-1090
  • Truncated cast aluminum frame
  • PPB polypropylene cone with half-roll rubber surround
  • Long-throw voice coil for high excursion
  • Shorting rings for reduced distortion
  • Under-spider and voice coil ventilation
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments. A powerful ferrite magnet system is coupled to a finite element analysis-designed suspension system, containing a linear spider design and rubber surround. The motor incorporates an aluminum shorting ring that reduces coil inductance, extending frequency response performance and reducing second harmonic distortion. A cast aluminum basket provides high structural rigidity, heat-sinking capacity for the motor, and additional ventilation under the spider that in combination with a vented cone neck reduces air compression effects. Peerless developed the proprietary and highly advanced Polypropylene Black (PPB) cone material used in the HDS PPB Series, creating a stiff but still dampened cone that remains stable even under the greatest sound pressures.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)50 Watts
  • Power Handling (max)100 Watts
  • Impedance8 ohms
  • Frequency Response50 to 4,000 Hz
  • Sensitivity88.5 dB 1W/1m
  • Voice Coil Diameter1.25"
  • Resonant Frequency (Fs)58 Hz
  • DC Resistance (Re)6.5 ohms
  • Voice Coil Inductance (Le)0.42 mH
  • Mechanical Q (Qms)2.3
  • Electromagnetic Q (Qes)0.53
  • Total Q (Qts)0.43
  • Compliance Equivalent Volume (Vas)0.44 ft.³
  • Mechanical Compliance of Suspension (Cms)0.43 mm/N
  • BL Product (BL)8.82 Tm
  • Diaphragm Mass Inc. Airload (Mms)17.34g
  • Maximum Linear Excursion (Xmax)5.38 mm
  • Surface Area of Cone (Sd)143 cm²
  • Cone MaterialPoly
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter7.18"
  • Baffle Cutout Diameter5.72"
  • Depth3.44"
  • # Mounting Holes6
  • Sealed Volume0.15 ft.³
  • Sealed F3101 Hz
  • Vented Volume0.45 ft.³
  • Vented F356 Hz
  • BrandPeerless by Tymphany
  • Model830874
  • Part Number264-1090
  • UPC844632084065
  • Product CategoryWoofers
    (5 Reviews)
  • Weight3.7 lbs.
View similar products to the Peerless by Tymphany 830874 6-1/2" PPB Cone HDS Woofer
