Peerless by Tymphany 830870 4" PPB Cone HDS Woofer
Brand:|Model: 830870|Part # 264-1070
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments.
OUT OF STOCK
Due In: 8/24/2016
List Price$49.99
You Save26%
$37.00
Buy 4+$35.65
Part # 264-1070
  • Truncated cast aluminum frame
  • PPB polypropylene cone with half-roll rubber surround
  • Long-throw voice coil
  • Shorting rings for reduced distortion
  • Under-spider and voice coil ventilation
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments. A powerful ferrite magnet system is coupled to a finite element analysis-designed suspension system, containing a linear spider design and rubber surround. The motor incorporates an aluminum shorting ring that reduces coil inductance, extending frequency response performance and reducing second harmonic distortion. A cast aluminum basket provides high structural rigidity, heat-sinking capacity for the motor, and additional ventilation under the spider that in combination with a vented cone neck reduces air compression effects. Peerless developed the proprietary and highly advanced Polypropylene Black (PPB) cone material used in the HDS PPB Series, creating a stiff but still dampened cone that remains stable even under the greatest sound pressures. .
  • Nominal Diameter4"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance8 ohms
  • Frequency Response90 to 6,000 Hz
  • Sensitivity85.9 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)91 Hz
  • DC Resistance (Re)5.2 ohms
  • Voice Coil Inductance (Le)0.16 mH
  • Mechanical Q (Qms)1.92
  • Electromagnetic Q (Qes)0.74
  • Total Q (Qts)0.53
  • Compliance Equivalent Volume (Vas)0.08 ft.³
  • Mechanical Compliance of Suspension (Cms)0.51 mm/N
  • BL Product (BL)4.94 Tm
  • Diaphragm Mass Inc. Airload (Mms)6.1g
  • Maximum Linear Excursion (Xmax)3 mm
  • Surface Area of Cone (Sd)56.8 cm²
  • Cone MaterialPoly
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter4.76"
  • Baffle Cutout Diameter3.74"
  • Depth2.09"
  • # Mounting Holes6
  • Sealed Volume0.07 ft.³
  • Sealed F3123 Hz
  • Vented Volume0.2 ft.³
  • Vented F360 Hz
  • BrandPeerless by Tymphany
  • Model830870
  • Part Number264-1070
  • UPC844632083969
  • Product CategoryWoofers
    (2 Reviews)
  • Weight2.1 lbs.
View similar products to the Peerless by Tymphany 830870 4" PPB Cone HDS Woofer
