Peerless by Tymphany 830869 8" Nomex Cone HDS Woofer
Brand:|Model: 830869|Part # 264-1098
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments.
List Price$101.99
You Save22%
$79.70
Buy 4+$77.17
Part # 264-1098
  • Truncated cast aluminum frame
  • Nomex cone with half-roll rubber surround
  • 1-1/4" diameter long-throw voice coil
  • Shorting rings for reduced distortion
  • Under-spider and voice coil ventilation
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments. A powerful ferrite magnet system is coupled to a finite element analysis-designed suspension system, containing a linear spider design and rubber surround. The motor incorporates an aluminum shorting ring that reduces coil inductance, extending frequency response performance and reducing second harmonic distortion. A cast aluminum basket provides high structural rigidity, heat-sinking capacity for the motor, and additional ventilation under the spider that in combination with a vented cone neck reduces air compression effects. The famous Peerless Nomex cone offers neutral, accurate audio reproduction.
  • Nominal Diameter8"
  • Power Handling (RMS)75 Watts
  • Power Handling (max)150 Watts
  • Impedance8 ohms
  • Frequency Response30 to 2,000 Hz
  • Sensitivity90.2 dB 1W/1m
  • Voice Coil Diameter1.25"
  • Resonant Frequency (Fs)30 Hz
  • DC Resistance (Re)5.9 ohms
  • Voice Coil Inductance (Le)0.63 mH
  • Mechanical Q (Qms)4.4
  • Electromagnetic Q (Qes)0.33
  • Total Q (Qts)0.31
  • Compliance Equivalent Volume (Vas)3.09 ft.³
  • Mechanical Compliance of Suspension (Cms)1.21 mm/N
  • BL Product (BL)8.92 Tm
  • Diaphragm Mass Inc. Airload (Mms)23.99g
  • Maximum Linear Excursion (Xmax)5.5 mm
  • Surface Area of Cone (Sd)227 cm²
  • Cone MaterialNomex
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.86"
  • Baffle Cutout Diameter7.48"
  • Depth3.52"
  • # Mounting Holes6
  • Sealed Volume0.57 ft.³
  • Sealed F367 Hz
  • Vented Volume1.6 ft.³
  • Vented F338 Hz
  • BrandPeerless by Tymphany
  • Model830869
  • Part Number264-1098
  • UPC844632084102
  • Product CategoryWoofers
    (4 Reviews)
  • Weight4.1 lbs.
View similar products to the Peerless by Tymphany 830869 8" Nomex Cone HDS Woofer
