Peerless by Tymphany 830860 5-1/4" PPB Cone HDS Woofer
Brand:|Model: 830860|Part # 264-1080
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments.
List Price$57.99
You Save25%
$43.25
Buy 4+$41.74
Part # 264-1080
  • Truncated cast aluminum frame
  • PPB polypropylene cone with half-roll rubber surround
  • Long-throw voice coil
  • Shorting rings for reduced distortion
  • Under-spider and voice coil ventilation
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments. A powerful ferrite magnet system is coupled to a finite element analysis-designed suspension system, containing a linear spider design and rubber surround. The motor incorporates an aluminum shorting ring that reduces coil inductance, extending frequency response performance and reducing second harmonic distortion. A cast aluminum basket provides high structural rigidity, heat-sinking capacity for the motor, and additional ventilation under the spider that in combination with a vented cone neck reduces air compression effects. Peerless developed the proprietary and highly advanced Polypropylene Black (PPB) cone material used in the HDS PPB Series, creating a stiff but still dampened cone that remains stable even under the greatest sound pressures.
  • Nominal Diameter5-1/4"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance8 ohms
  • Frequency Response60 to 5,000 Hz
  • Sensitivity85.8 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)62 Hz
  • DC Resistance (Re)5.9 ohms
  • Voice Coil Inductance (Le)0.27 mH
  • Mechanical Q (Qms)2.21
  • Electromagnetic Q (Qes)0.59
  • Total Q (Qts)0.47
  • Compliance Equivalent Volume (Vas)0.3 ft.³
  • Mechanical Compliance of Suspension (Cms)0.74 mm/N
  • BL Product (BL)5.9 Tm
  • Diaphragm Mass Inc. Airload (Mms)9g
  • Maximum Linear Excursion (Xmax)3.5 mm
  • Surface Area of Cone (Sd)89.9 cm²
  • Cone MaterialPoly
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.99"
  • Baffle Cutout Diameter4.72"
  • Depth2.76"
  • # Mounting Holes6
  • Sealed Volume0.1 ft.³
  • Sealed F3117 Hz
  • Vented Volume0.31 ft.³
  • Vented F364 Hz
  • BrandPeerless by Tymphany
  • Model830860
  • Part Number264-1080
  • UPC844632084010
  • Product CategoryWoofers
    (3 Reviews)
  • Weight2.5 lbs.
View similar products to the Peerless by Tymphany 830860 5-1/4" PPB Cone HDS Woofer
