Peerless by Tymphany 830669 12" Paper Cone SLS Subwoofer
Brand:|Model: 830669|Part # 264-1118
The Peerless SLS Series combines high quality performance with an affordable design.
List Price$129.99
You Save25%
$96.95
Buy 4+$89.80
Part # 264-1118
  • Premium sculpted stamped steel chassis
  • Coated paper cone with rubber edge
  • Shorting ring in magnet system
The Peerless SLS Series combines high quality performance with an affordable design. The SLS drivers are ideal for use in systems with high power handling requirements, and are a logical choice for use with the SDS line of transducers.
  • Nominal Diameter12"
  • Power Handling (RMS)110 Watts
  • Power Handling (max)220 Watts
  • Impedance8 ohms
  • Frequency Response30 to 2,000 Hz
  • Sensitivity89.8 dB 2.83V/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)31 Hz
  • DC Resistance (Re)5.6 ohms
  • Voice Coil Inductance (Le)1.12 mH
  • Mechanical Q (Qms)7.1
  • Electromagnetic Q (Qes)0.58
  • Total Q (Qts)0.54
  • Compliance Equivalent Volume (Vas)4.68 ft.³
  • Mechanical Compliance of Suspension (Cms)0.35 mm/N
  • BL Product (BL)11.88 Tm
  • Diaphragm Mass Inc. Airload (Mms)74.11g
  • Maximum Linear Excursion (Xmax)8.3 mm
  • Surface Area of Cone (Sd)522.8 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter12"
  • Baffle Cutout Diameter10.91"
  • Depth5.95"
  • Bolt Circle Diameter12"
  • # Mounting Holes8
  • Sealed Volume2.41 ft.³
  • Sealed F351 Hz
  • Vented Volume8 ft.³
  • Vented F327 Hz
  • BrandPeerless by Tymphany
  • Model830669
  • Part Number264-1118
  • UPC844632084201
    (3 Reviews)
  • Weight8.35 lbs.
View similar products to the Peerless by Tymphany 830669 12" Paper Cone SLS Subwoofer
