Peerless by Tymphany 830657 6-1/2" Paper Cone SDS Woofer
Brand:|Model: 830657|Part # 264-1088
The Peerless Superior Dynamic Sounds (SDS) Series provides the lowest cost/highest-quality woofers in the industry today.
List Price$34.99
You Save38%
$21.70
Buy 4+$19.98
Part # 264-1088
  • Premium sculpted stamped steel chassis
  • Coated paper cone with rubber edge
  • Smooth, extended response
The Peerless Superior Dynamic Sounds (SDS) Series provides the lowest cost/highest-quality woofers in the industry today. The SDS woofers are characterized by their very smooth frequency response all the way into the midrange, with low distortion and consistent off-axis performance. Applying the best in Danish engineering, but manufactured to be very affordable, these audio transducers are ideal for use in small surround sound systems and other hi-fi applications.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)60 Watts
  • Power Handling (max)110 Watts
  • Impedance8 ohms
  • Frequency Response40 to 4,000 Hz
  • Sensitivity88.2 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)45 Hz
  • DC Resistance (Re)6 ohms
  • Voice Coil Inductance (Le)0.38 mH
  • Mechanical Q (Qms)2.74
  • Electromagnetic Q (Qes)0.55
  • Total Q (Qts)0.46
  • Compliance Equivalent Volume (Vas)1.09 ft.³
  • Mechanical Compliance of Suspension (Cms)1.1 mm/N
  • BL Product (BL)5.98 Tm
  • Diaphragm Mass Inc. Airload (Mms)11.5g
  • Maximum Linear Excursion (Xmax)3.46 mm
  • Surface Area of Cone (Sd)141 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter7.17"
  • Baffle Cutout Diameter5.71"
  • Depth2.72"
  • # Mounting Holes6
  • Sealed Volume0.4 ft.³
  • Sealed F389 Hz
  • Vented Volume1.27 ft.³
  • Vented F345 Hz
  • BrandPeerless by Tymphany
  • Model830657
  • Part Number264-1088
  • UPC844632084058
  • Product CategoryWoofers
  • Weight2 lbs.
View similar products to the Peerless by Tymphany 830657 6-1/2" Paper Cone SDS Woofer
