Peerless by Tymphany 830656 5-1/4" Paper Cone SDS Woofer
Brand:|Model: 830656|Part # 264-1078
The Peerless Superior Dynamic Sounds (SDS) Series provides the lowest cost/highest-quality woofers in the industry today.
List Price$25.99
You Save31%
$17.90
Buy 4+$15.08
Part # 264-1078
  • Premium sculpted stamped steel chassis
  • Coated paper cone with rubber edge
  • Smooth, extended response
The Peerless Superior Dynamic Sounds (SDS) Series provides the lowest cost/highest-quality woofers in the industry today. The SDS woofers are characterized by their very smooth frequency response all the way into the midrange, with low distortion and consistent off-axis performance. Applying the best in Danish engineering, but manufactured to be very affordable, these audio transducers are ideal for use in small surround sound systems and other hi-fi applications.
  • Nominal Diameter5-1/4"
  • Power Handling (RMS)60 Watts
  • Power Handling (max)110 Watts
  • Impedance8 ohms
  • Frequency Response50 to 5,000 Hz
  • Sensitivity84.5 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)57 Hz
  • DC Resistance (Re)6.1 ohms
  • Voice Coil Inductance (Le)0.37 mH
  • Mechanical Q (Qms)3.6
  • Electromagnetic Q (Qes)0.7
  • Total Q (Qts)0.59
  • Compliance Equivalent Volume (Vas)0.31 ft.³
  • Mechanical Compliance of Suspension (Cms)0.83 mm/N
  • BL Product (BL)5.36 Tm
  • Diaphragm Mass Inc. Airload (Mms)9.3g
  • Maximum Linear Excursion (Xmax)3.46 mm
  • Surface Area of Cone (Sd)86.6 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.98"
  • Baffle Cutout Diameter4.61"
  • Depth2.23"
  • # Mounting Holes6
  • Sealed Volume0.2 ft.³
  • Sealed F399 Hz
  • Vented Volume0.58 ft.³
  • Vented F348 Hz
  • BrandPeerless by Tymphany
  • Model830656
  • Part Number264-1078
  • UPC844632084003
  • Product CategoryWoofers
    (12 Reviews)
  • Weight1.65 lbs.
View similar products to the Peerless by Tymphany 830656 5-1/4" Paper Cone SDS Woofer
