299-968_ALT_0
299-968_ALT_1
Peerless 850443 5-1/2" Shielded Composite Cone Woofer 8 Ohm
Brand:|Part # 299-968
Peerless designed the 850443 5" shielded woofer for a well-known speaker manufacturer using much of the same technology found in their CSX speakers. Save nearly half off the retail price of this Danish-made speaker through this exclusive Parts Express buyout! Limited quantities.
Part # 299-968
  • Made in Denmark
  • Sandwiched-cone design for a linear frequency response
  • Shielded for use near sensitive electronics
  • High-loss rubber surround
This Danish-made 5" shielded woofer from Peerless (model number 850443) was built using many of the features found in their CSX line of speakers, including a laminated sandwiched cone, a double-bonded inverted dust cap, high-loss rubber surround, and a vented cone to minimize compression. A shielded motor not only makes this woofer safe to use around sensitive electronics, it also focuses the magnet flux in the gap for higher sensitivity and a lower Qts figure.
Suitable applications for this woofer include two-way bookshelf speaker, midrange and midbass in three-way (and larger) speakers, and mobile audio applications as a door or deck speaker. Save 50% off the original retail price through this Parts Express exclusive buyout. Hurry, quantities are extremely limited!
  • Nominal Diameter5-1/2"
  • Power Handling (RMS)50 Watts
  • Power Handling (max)100 Watts
  • Impedance8 ohms
  • Frequency Response48 to 5,800 Hz
  • Sensitivity88 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)48 Hz
  • DC Resistance (Re)6.1 ohms
  • Voice Coil Inductance (Le)0.84 mH
  • Mechanical Q (Qms)2.63
  • Electromagnetic Q (Qes)0.58
  • Total Q (Qts)0.47
  • Compliance Equivalent Volume (Vas)0.34 ft.³
  • Maximum Linear Excursion (Xmax)4 mm
  • Cone MaterialPoly Composite
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.75"
  • Baffle Cutout Diameter4.75"
  • Depth2.875"
  • Bolt Circle Diameter5.25"
  • # Mounting Holes4
  • Sealed Volume0.18 ft.³
  • Sealed F380 Hz
  • Vented Volume0.48 ft.³
  • Vented F339 Hz
  • BrandFactory Buyouts
  • Part Number299-968
  • UPC848864006321
  • Product CategoryProducts
  • Weight2.6 lbs.
View similar products to the Peerless 850443 5-1/2" Shielded Composite Cone Woofer 8 Ohm
in the Products product category.
