Peerless 835028 10" XLS Shallow Subwoofer
Brand:|Model: 835028
The Peerless 835028 motor-above-cone (MAC) shallow subwoofer features a cast aluminum basket for structural strength and a heat-sinked neodymium motor for high power handling capability.
List Price$230.99
Regular Price$173.26
You Save43%
Sale Price
$98.00
Part # 264-1105
  • Superbly engineered for in-wall applications
  • Heavy duty cast aluminum basket
  • Unique reverse-mounted neodymium motor reduces depth
  • Generous heatsinking and "open-air" voice coil promote cooling
  • Carefully damped paper cone, rubber surround, flat spider
The Peerless 835028 motor-above-cone (MAC) shallow subwoofer features a cast aluminum basket for structural strength and a heat-sinked neodymium motor for high power handling capability. Thanks to its slim design and imaginative engineering, the 835028 10" subwoofer speaker is ideal for in-wall applications. Coated paper cone, reverse half-roll rubber surround, and heavy braided lead wires stitched into the deeply corrugated flat spider.
  • Nominal Diameter10"
  • Power Handling (RMS)160 Watts
  • Power Handling (max)320 Watts
  • Impedance4 ohms
  • Frequency Response20 to 500 Hz
  • Sensitivity81.3 dB 1W/1m
  • Voice Coil Diameter2.02"
  • Resonant Frequency (Fs)34 Hz
  • DC Resistance (Re)3.16 ohms
  • Voice Coil Inductance (Le)0.91 mH
  • Mechanical Q (Qms)6.8
  • Electromagnetic Q (Qes)0.55
  • Total Q (Qts)0.51
  • Compliance Equivalent Volume (Vas)1.12 ft.³
  • Mechanical Compliance of Suspension (Cms)0.2 mm/N
  • BL Product (BL)11.33 Tm
  • Diaphragm Mass Inc. Airload (Mms)106.5g
  • Maximum Linear Excursion (Xmax)9 mm
  • Surface Area of Cone (Sd)0.31 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter10.45"
  • Baffle Cutout Diameter9.016"
  • Depth3.53"
  • # Mounting Holes6
  • Sealed Volume0.74 ft.³
  • Sealed F353 Hz
  • Vented Volume1.86 ft.³
  • Vented F325 Hz
  • BrandPeerless
  • Model835028
  • Part Number264-1105
  • UPC844632089787
  • Weight6 lbs.
View similar products to the Peerless 835028 10" XLS Shallow Subwoofer
Is this suitable for a down-firing configuration in a sealed enclosure ? What cabinet size is recommended in a down-firing, sealed configuration ?   I am thinking of putting it between the two front sets in a minivan, with the amp on top of the cabinet.
Asked by: avkesq
Yes this will work fine down-firing. I would recommend a volume of 0.5 cubic feet for an F3 of 50 Hz.
Date published: 2015-05-20
Would this fit in a standard 2x4 wall? What is the depth when front mounted? Is the speaker rated for ceiling mounting?
Asked by: MIelectronicengineer
This will work in a standard stud wall, it is only ~2.75" deep. It will need to be in its own chamber though, it is not recommended for free air applications. It will work in a ceiling.
Date published: 2015-03-24
Would this driver be suitable for a face up infinite baffle application?  I'm thinking the rear deck of a sedan, the shallow depth would keep them from hanging down into the trunk too far.
Asked by: Superspeeder
Yes, it will be suitable.
Answered by: MattW
Date published: 2015-04-22
How far from the front of the mounting flange does the motor protrude?
Asked by: Spooney
It measure at 3/4" or 19.1mm.
Answered by: MattW
any thoughts or ideas for a car audio application with this subwoofer? also would it be feasable to use passive radiators with these?
Asked by: Boomer88
These are a popular option for car audio applications. A sealed box will provide very good results, but a ported box will help with overall low end. Due to the volume of the box passive radiators are not very practical, but they will work well. This woofer in 1.8 cubic feet with two of the Dayton SD270-PR's with 100 grams added to each will provide a tuning frequency of 32 Hz and an F3 of 31 Hz.
Frequency response for sealed enclosure. If I were to place this speaker in-wall in a sealed enclosure 0.8 cubic feet as suggested would would my expected -3dB frequency response be?  Am I reading the specification correctly that it would be about 53 Hz?
Asked by: klep
Yes your F3 in that volume will be in the low 50's with useable response into the low 30's with room gain factored in.
Date published: 2014-04-29
  • 2015-07-30T08:13CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.5
  • co_hasquestionsanswers, tq_10
  • loc_en_US, sid_264-1105, PRD, sort_recentQuestionsFirst
