Peerless 835026 8" Aluminum Cone HDS Woofer
Brand:|Model: 835026
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments.
List Price$127.99
Regular Price$95.67
You Save12%
Sale Price
$84.00
Part # 264-1100
  • Truncated cast aluminum frame
  • Aluminum cone with half-roll rubber surround
  • 1-1/2" diameter long-throw voice coil
  • Shorting rings for reduced distortion
  • Under-spider and voice coil ventilation
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments. A powerful ferrite magnet system is coupled to a finite element analysis-designed suspension system, containing a linear spider design and rubber surround. The motor incorporates an aluminum shorting ring that reduces coil inductance, extending frequency response performance and reducing second harmonic distortion. A cast aluminum basket provides high structural rigidity, heat-sinking capacity for the motor, and additional ventilation under the spider that in combination with a vented cone neck reduces air compression effects. The aluminum cone combines high strength with low moving mass, offering superb transient response and sharp definition.
  • Nominal Diameter8"
  • Power Handling (RMS)75 Watts
  • Power Handling (max)150 Watts
  • Impedance8 ohms
  • Frequency Response20 to 3,000 Hz
  • Sensitivity86.8 dB 2.83V/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)27 Hz
  • DC Resistance (Re)5.5 ohms
  • Voice Coil Inductance (Le)0.57 mH
  • Mechanical Q (Qms)4.3
  • Electromagnetic Q (Qes)0.46
  • Total Q (Qts)0.41
  • Compliance Equivalent Volume (Vas)2.33 ft.³
  • Mechanical Compliance of Suspension (Cms)0.87 mm/N
  • BL Product (BL)8.96 Tm
  • Diaphragm Mass Inc. Airload (Mms)38.57g
  • Maximum Linear Excursion (Xmax)6.02 mm
  • Surface Area of Cone (Sd)232.4 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.86"
  • Baffle Cutout Diameter7.5"
  • Depth4.27"
  • # Mounting Holes6
  • Sealed Volume0.65 ft.³
  • Sealed F356 Hz
  • Vented Volume1.94 ft.³
  • Vented F331 Hz
  • BrandPeerless
  • Model835026
  • Part Number264-1100
  • UPC844632084119
  • Product CategoryWoofers
    (1 Reviews)
  • Weight5.4 lbs.
View similar products to the Peerless 835026 8" Aluminum Cone HDS Woofer
Peerless 835026 8" Aluminum Cone HDS Woofer is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from Outstanding Look and PerformanceFirst I like to say these woofers are true Treasures! I had a set of Quest QT88 Towers with a set of Hybrid 8" woofer made of nothing more then (laminated paper cone). I got 4 X Peerless 835026 8" Aluminum Cone HDS Woofer to replace the current ones in the towers.The replacement required some trimming with the spin saw, patience, knowledge, glue, silicone, a bit of Polyfill, Black Tremclad plastic paint to cover the new Aesthetic gap created by the new almost perfect fit dimension of the new Woofers.The result is, more better look, lighter...more rigid cone, less distortion, more pounding, more thump and joy, joy....audio joy!Please note these Peerless woofers are made in Denmark and are married with (in my case) a set of Peerless 812687 Soft Dome Tweeters as well made in Denmark.I recommend these "Thumpers" to anybody that wants quality and looks or want to upgrade any current laminated paper cone or polypropylene woofers....!
Date published: 2010-09-09
  • 2015-09-04T07:16CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_264-1100, PRD, sort_mostRecent
in the picture, it looks like there are two outside diameter measurements. can you please provide me with the shorter diameter as i need slightly less than 8 inches for my application
Asked by: rosso629
When measured from flat edge to flat edge, it is 8.07".
Date published: 2015-03-24
  • 2015-09-03T08:03CST
  • loc_en_US, sid_264-1100, PRD, sort_recentQuestionsFirst
