Peerless 835017 12" Aluminum Cone XXLS Subwoofer
Brand:| Model: 835017
This series of state-of-the-art subwoofers continues to enhance Peerless's reputation for delivering the highest quality components for bass.
  • 12.5 mm of linear excursion
  • Extremely durable aluminum cone
  • Cast aluminum frame
  • Flat spider and HD rubber half roll surround
  • Massive stacked magnet
264-1114
Weight: 15.4 lbs.
IN STOCK
List Price$327.99
You Save25%
$245.00
Buy 4-up$233.26
Part # 264-1114
This series of state-of-the-art subwoofers continues to enhance Peerless's reputation for delivering the highest quality components for bass. Called the XXLS—for "Xpanded Extra Long Stroke"—these audio transducers add even more excursion to the Peerless XLS line while completely eliminating distortion. The XXLS line features a strong yet attractive cast frame, reinforced aluminum cone, flat spider, and generous under-spider venting. The magnet system incorporates multiple distortion-canceling fixtures.
  • Nominal Diameter12"
  • Power Handling (RMS)175 Watts
  • Power Handling (max)350 Watts
  • Impedance4 ohms
  • Frequency Response19 to 1,000 Hz
  • Sensitivity88.6 dB 2.83V/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)22 Hz
  • DC Resistance (Re)2.5 ohms
  • Voice Coil Inductance (Le)0.53 mH
  • Mechanical Q (Qms)10.83
  • Electromagnetic Q (Qes)0.4
  • Total Q (Qts)0.39
  • Compliance Equivalent Volume (Vas)4.8 ft.³
  • Mechanical Compliance of Suspension (Cms)0.42 mm/N
  • BL Product (BL)10.58 Tm
  • Diaphragm Mass Inc. Airload (Mms)131.4g
  • Maximum Linear Excursion (Xmax)12.5 mm
  • Surface Area of Cone (Sd)483.1 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.12"
  • Baffle Cutout Diameter10.91"
  • Depth6.38"
  • # Mounting Holes6
  • Sealed Volume1.04 ft.³
  • Sealed F349 Hz
  • Vented Volume2.64 ft.³
  • Vented F329 Hz
  • BrandPeerless
  • Model835017
  • Part Number264-1114
  • UPC844632084188
  • Weight15.4 lbs.
View similar products to the Peerless 835017 12" Aluminum Cone XXLS Subwoofer
What size sealed box would this sub require?
Also, can this sub be used for car audio?
Asked by: Lex426
I WOULD USE ANOTHER TYPE OF WOOFER FOR CAR AND AT THE PRICE I WOULD CALL TECH SUPPORT FOR EXACT SIZE, APPROX 1.25 CUFT WITH HEAVY BRACING ,3/4 IN MDF,POLY FIL STUFFED AND DECOUPLE IT FROM FLOOR WOULD THUMP WELL ,,BUT THEN THE DESIGN TO GO UP TO 1000 HZ WOULD BE WASTED ,, IT IS MEANT FOR THREE WAY DESIGN
Answered by: digitalhaven 53
Date published: 2013-11-09
Customer projects that include: Peerless 835017 12" Aluminum Cone XXLS Subwoofer
