299-271_ALT_0
299-271_ALT_2
Peerless 830970 2" Full Range Driver 4 Ohm
Brand:|Part # 299-271
Tymphany/Peerless full range drivers set the standard for quality audio in products including flat panel televisions and sound bars, MP3 and cell phone docking stations, and multimedia PCs.
  • Neodymium magnet
  • Double-vented motor
  • Anodized aluminum center dome
  • Distortion-reducing semi-progressive surround
  • Copper pole piece cap controls impedance
Tymphany/Peerless full range drivers set the standard for quality audio in products including flat panel televisions and sound bars, MP3 and cell phone docking stations, and multimedia PCs. With their high power handling, smooth, even dispersion, and low distortion, the Tymphany/Peerless full range drivers can be paired with the Tymphany LAT250 for great bass performance. A neodymium motor structure and double-venting system keeps dynamic range intact, as the transducer can handle more power and dissipate excess heat efficiently. An anodized aluminum dome provides superior sound dispersion and off-axis response. A semi-progressive surround reduces distortion, especially at high output through long excursion. The driver's direct connected dome dust cap (attached to the magnet system voice coil) improves dispersion at high frequencies, providing superior sound at the higher frequencies. The inserted copper cap on the pole piece ensures control of the system impedance, thereby extending the upper frequency range. Buyout, limited quantities. Some stock may have Tymphany identification and/or part numbers.
Specifications: • Power handling: 7 watts RMS/60 watts max • VCdia: 1" • Le: 0.2 mH • Impedance: 4 ohms • Re: 3.8 ohms • Frequency response: 150-20,000 Hz • Fs: 147.5 Hz • SPL: 82 dB 1W/1m • Vas: 0.07 cu. ft. • Qms: 3.06 • Qes: 0.7 • Qts: 0.57 • Xmax: 1.8 mm • Dimensions: Overall diameter: 2.17" (2.56" diagonally ear-to-ear), Cutout diameter: 1.97", Depth: 1.31".
  • BrandPeerless
  • Part Number299-271
  • UPC844632078057
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (11 Reviews)
  • Weight0.35 lbs.
View similar products to the Peerless 830970 2" Full Range Driver 4 Ohm
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
