Peerless 830946 6-1/2" Paper Cone Woofer Speaker 4 Ohm
Brand:|Model: 830946|Part # 264-1148
The Peerless SLS Series 830946 6-1/2" woofer is a versatile, solidly-performing choice for midbass, woofer, or subwoofer applications.
List Price$78.99
You Save25%
$59.21
Buy 4+$54.17
Part # 264-1148
  • Works great as a subwoofer in compact systems
  • Sculpted and vented stamped steel frame promotes motor cooling
  • Powerful ceramic magnet system with bumped back plate for full excursion
  • Coated paper cone with oversized half-roll rubber surround
  • Long-throw 1-1/2" voice coil
  • Aluminum shorting ring in magnetic gap reduces distortion
  • 4 ohm nominal impedance
A new addition to the SLS Series of speakers, the Peerless 830946 6-1/2" woofer features a paper cone, wide rubber half-roll surround, and hefty ceramic ferrite magnet with distortion-reducing aluminum shorting ring. Audio is reproduced with accuracy and detail.
The speaker's distinctively sculpted truncated steel frame facilitates close driver spacing or a narrower mounting baffle, and its extensive under-spider venting promotes voice coil cooling for reduced power compression and improved long term reliability. The 830946 will perform superbly as a dedicated low-mid bass driver, as well as delivering solid output when used as a compact subwoofer.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)75 Watts
  • Power Handling (max)150 Watts
  • Impedance4 ohms
  • Frequency Response20 to 1,000 Hz
  • Sensitivity82 dB 1W/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)42 Hz
  • DC Resistance (Re)2.7 ohms
  • Voice Coil Inductance (Le)0.65 mH
  • Mechanical Q (Qms)4.92
  • Electromagnetic Q (Qes)0.38
  • Total Q (Qts)0.35
  • Compliance Equivalent Volume (Vas)0.4 ft.³
  • Mechanical Compliance of Suspension (Cms)0.47 mm/N
  • BL Product (BL)7.6 Tm
  • Diaphragm Mass Inc. Airload (Mms)30.5g
  • Maximum Linear Excursion (Xmax)8.2 mm
  • Surface Area of Cone (Sd)123.5 cm²
  • Cone MaterialPaper
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.46 across flats, 7.165"
  • Baffle Cutout Diameter5.79"
  • Depth3.28"
  • Bolt Circle Diameter6.67"
  • # Mounting Holes6
  • Sealed Volume0.09 ft.³
  • Sealed F395 Hz
  • Vented Volume0.21 ft.³
  • Vented F355 Hz
  • BrandPeerless
  • Model830946
  • Part Number264-1148
  • UPC844632092688
  • Product CategoryWoofers
    (3 Reviews)
  • Weight5.55 lbs.
View similar products to the Peerless 830946 6-1/2" Paper Cone Woofer Speaker 4 Ohm
Peerless 830946 6-1/2" Paper Cone Woofer Speaker 4 Ohm is rated 4.6667 out of 5 by 3.
Rated 5 out of 5 by from solara great rear deck fillI bought these to add some rear fill in a Toyota solara. Just running off a Sony CD player they sounded amazing. Lots of bass for a great sq sound. I have owned image dynamics 8" s . The sq is really good for being free air in the trunk with about 22 watts RMS. I plan on amplifying them and debating on even running my two 8s. They are not totally broke in but I am sure with time they will even play lower. Used a little rammat and tamed the vibrations down. Definitely will fill out a modest sq system.
Date published: 2015-04-25
Rated 4 out of 5 by from Great bass and mid bass. Definitely not a subRunning these in a front door panel. Definitely hits hard so make sure to secure properly. I had to fiberglass the door panels to keep them under control.Very nice for what they are. Don't ask too low of them and you will not be disappointed.DO NOT RUN OVER 800Hz. They will complain.
Date published: 2015-04-21
Rated 5 out of 5 by from Great purchase.I am very please with the product, i am so please i made 2 more purchases.
Date published: 2012-10-29
  • 2016-02-11T06:37CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_264-1148, PRD, sort_mostRecent
In the back of a Corvette C4 I have maybe 1 cf, original 6 X9 are sad speakers. I will well sound insulate, I am considering these as well as the Tang Bang 6 1/2 sub. I can install either sealed or vario, no room for vented. Thoughts?
Asked by: Vic2054
Date published: 2015-12-08
thinking on using this in the .23 cubic foot knock down enclosure. what size vent would it take to get the f3 stated?
Asked by: 707mike
The port required for these numbers would have to be external, unless you wanted to use passive radiators. The required port size for this F3 is 2" diameter and 19" long.If you wanted to use a pair of the 295-498 passive radiators, you could add 50 grams to each and get the same results as well.
Date published: 2015-01-06
I am thinking of using this woofer with the Fountek FE85 full range driver in a compact stand mount design...  The woofer would be side firing... Could i run the Peerless full range and high pass the Fountek at 800hz?  Bad idea side firing at this FR?
Asked by: Henk
I generally wouldn't recommend crossing a side firing woofer over much above 250 Hz, although the Fountek will handle a crossover point this low. I would consider just dropping the crossover point a bit and this should work. The Fountek will need to be in its own chamber as well.
Date published: 2014-12-11
Is this the woofer used in the meadowlark K2 speakers? I are these P17' s. Trying to repair my blown woofer.
Asked by: mikc518
We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2014-12-04
In a .35 cu ft enclosure with one of these drivers and a 1.5" port that is 10" in length tunes the box to 35 hz. Will a single flared 1.5" port have excessive port turbulence in this scenario?  Thanks!
Asked by: RussD964
With anything more than about 30 watts of power the port noise will more than likely be audible.
Date published: 2014-05-28
can i use this woofer as a subwoofer?
Asked by: javz
Technically you can use any woofer as a subwoofer but whether it will work well or not depends on the application in question. This has decent Xmax and power handling, but it also has a high Fs and requires a very small vented box which means it will not be very good below about 60 Hz. This would not be my first choice for a subwoofer in this size.
Date published: 2014-04-04
  • 2016-02-11T07:18CST
  • co_hasquestionsanswers, tq_10
  • loc_en_US, sid_264-1148, PRD, sort_recentQuestionsFirst
