264-1094_ALT_0
Peerless 830883 6-1/2" Nomex Cone HDS Woofer
Brand:| Model: 830883
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments.
  • Peerless HDS Exclusive Series
  • Cast aluminum frame
  • Nomex cone with half-roll rubber surround
  • Long-throw voice coil
  • Shorting rings for reduced distortion
  • Under-spider and voice coil ventilation
  • Aluminum phase plug improves off-axis linearity
264-1094
Weight: 3.85 lbs.
IN STOCK
List Price$105.99
You Save18%
$87.05
Buy 4-up$79.63
Part # 264-1094
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments. A powerful ferrite magnet system is coupled to a finite element analysis-designed suspension system, containing a linear spider design and rubber surround. The motor incorporates an aluminum shorting ring that reduces coil inductance, extending frequency response performance and reducing second harmonic distortion. A cast aluminum basket provides high structural rigidity, heat-sinking capacity for the motor, and additional ventilation under the spider that in combination with a vented cone neck reduces air compression effects. The famous Peerless Nomex cone offers neutral, accurate audio reproduction.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance8 ohms
  • Frequency Response40 to 3,000 Hz
  • Sensitivity87.2 dB 2.83V/1m
  • Voice Coil Diameter1.25"
  • Resonant Frequency (Fs)43 Hz
  • DC Resistance (Re)5.9 ohms
  • Voice Coil Inductance (Le)0.18 mH
  • Mechanical Q (Qms)2.2
  • Electromagnetic Q (Qes)0.46
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)0.81 ft.³
  • Mechanical Compliance of Suspension (Cms)0.8 mm/N
  • BL Product (BL)7.7 Tm
  • Diaphragm Mass Inc. Airload (Mms)17.34g
  • Maximum Linear Excursion (Xmax)5.62 mm
  • Surface Area of Cone (Sd)143.1 cm²
  • Cone MaterialNomex
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter7.09"
  • Baffle Cutout Diameter5.75"
  • Depth3.43"
  • # Mounting Holes6
  • Sealed Volume0.15 ft.³
  • Sealed F3100 Hz
  • Vented Volume0.41 ft.³
  • Vented F358 Hz
  • BrandPeerless
  • Model830883
  • Part Number264-1094
  • UPC844632084089
  • Product CategoryWoofers
  • Weight3.85 lbs.
View similar products to the Peerless 830883 6-1/2" Nomex Cone HDS Woofer
would this be suitable for an open baffle autosound install in doors?
Asked by: Kristopher
This depends on how low you need them to play. Pretty much anything will work, although the amount of low end you get will be the limiting factor. With these mounted IB they will not produce much below 60-70 Hz and a high pass filter is recommended.
Date published: 2014-10-28
crossover and is this suitable?
looking to make a pair of 2 way bookshelf speakers and would love to use ribbon tweeters, the Fountek Neo X 1.0 Ribbon Tweeters to be precise, which recommend an Xover of 2.5KHz at 18dB/octave. will this be suitable?
Asked by: ben199
Yes that will work fine for these drivers.
Date published: 2013-09-23
crossover & box
Hi wanted to know what size box to use with this driver?along with the Morel CAT408.And what cross overshould I use?
Asked by: Alexandria
The recommended enclosure for this woofer is 0.6 cubic feet vented with a 2" diameter port that is 5-1/2" long. This will tune the box to 43 Hz. I would recommend a crossover no lower than 2kHz.
Date published: 2013-10-19
  • 2015-04-27T10:10CST
  • loc_en_US, sid_264-1094, PRD, sort_recentQuestionsFirst
Customer projects that include: Peerless 830883 6-1/2" Nomex Cone HDS Woofer
