Peerless 830669 12" Paper Cone SLS Subwoofer
Brand:|Model: 830669|Part # 264-1118
The Peerless SLS Series combines high quality performance with an affordable design.
List Price$129.99
You Save25%
$96.95
Buy 4+$89.80
Part # 264-1118
  • Premium sculpted stamped steel chassis
  • Coated paper cone with rubber edge
  • Shorting ring in magnet system
The Peerless SLS Series combines high quality performance with an affordable design. The SLS drivers are ideal for use in systems with high power handling requirements, and are a logical choice for use with the SDS line of transducers.
  • Nominal Diameter12"
  • Power Handling (RMS)110 Watts
  • Power Handling (max)220 Watts
  • Impedance8 ohms
  • Frequency Response30 to 2,000 Hz
  • Sensitivity89.8 dB 2.83V/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)31 Hz
  • DC Resistance (Re)5.6 ohms
  • Voice Coil Inductance (Le)1.12 mH
  • Mechanical Q (Qms)7.1
  • Electromagnetic Q (Qes)0.58
  • Total Q (Qts)0.54
  • Compliance Equivalent Volume (Vas)4.68 ft.³
  • Mechanical Compliance of Suspension (Cms)0.35 mm/N
  • BL Product (BL)11.88 Tm
  • Diaphragm Mass Inc. Airload (Mms)74.11g
  • Maximum Linear Excursion (Xmax)8.3 mm
  • Surface Area of Cone (Sd)522.8 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter12"
  • Baffle Cutout Diameter10.91"
  • Depth5.95"
  • Bolt Circle Diameter12"
  • # Mounting Holes8
  • Sealed Volume2.41 ft.³
  • Sealed F351 Hz
  • Vented Volume8 ft.³
  • Vented F327 Hz
  • BrandPeerless
  • Model830669
  • Part Number264-1118
  • UPC844632084201
    (3 Reviews)
  • Weight8.35 lbs.
View similar products to the Peerless 830669 12" Paper Cone SLS Subwoofer
Peerless 830669 12" Paper Cone SLS Subwoofer is rated 4.6667 out of 5 by 3.
Rated 5 out of 5 by from Great Sounding SubI bought these subs for use in an OB project (The Manzanita). They sound just terrific!
Date published: 2014-04-05
Rated 5 out of 5 by from best for the moneyIve got these in a 4 way system, active for 3 speakers, passive for the 3rd to tweeter, in a Q.707 sealed cab, analog system. There is a nice linear response about 40Hz. , so to cover two octaves they are crossed at 140- 160Hz. They have a clear, rapid response. They are not room shaking, but they are not for home theater. Everything from The Who to classical sound great. Im not a port speaker fan at all. To me the bass has a loss of warmth and the sound too hollow. On the other hand, if you dont mind the large bass cab needed for linear response in a sealed system the 12 in peerless is great. All my speakers crossover at aprox 2 octaves. I use a SLS 10 in peerless crossed at 640HZ. The combination is spectacular.
Date published: 2013-03-14
Rated 4 out of 5 by from Peerless 12"slsI dont understand why there are little to no reviews on this product. I have these paired with a dayton 12" in a 3 way setup along with dayton 5 1/4 and dayton tweeter. The sound is absolutely wonderful, deep and precise. I could say the same about the dayton but I was one of the unlucky few to get one that buzzed at moderate volumes. (To get rid of the buzzing I paired it with this peerless and wired it to 4 ohms on the dayton 3 way xover. handy little feature and no idea why it worked. Maybe the division of power between the two). Love the sound it produces. I will be replacing the daytons with two more of the peerless drivers as soon as I can.
Date published: 2012-08-11
  • 2016-02-08T06:28CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_264-1118, PRD, sort_mostRecent
Hi I would like to use this peerless 830669 with a Dayton Audio SD315-PR 12" Passive Radiator in a sealed enclosure this would be a side firing woofer can you suggest a enclosure size as small as possible
Asked by: Brian j
I would recommend using two passives with this woofer. 2.0 cubic feet will work with 100 grams added to each passive. This will give you a tuning frequency of about 32 Hz.
Date published: 2015-01-27
Would this driver work well in a 3 cubic ft cabinet for sub duty only?
Asked by: Akoni59
Assuming 3 cubic feet sealed, this driver will work pretty well. You can expect in room response into the low 30's. A pair in their own enclosures would be better, powered in parallel with our Dayton SA230 amplifier.
Date published: 2014-07-25
Would this driver be a good choice for a (M&K style) push-pull design?  Would this have equivalent output and deep extension as an M&K sub?
Asked by: subsonic36
This will work in a smaller sealed type design like that. If you have an amplifier with a bass boost feature, this will reach in room response to the low 30's which is as low as an M&K design.
Date published: 2014-01-28
i wanna biuld a ht box for 2 of these with a bash 300 watt amp?
i listen to classic rock and techno so i want it to perform well with music and movies and i.m trying for sound quality not to blow me and my neighbors away any help would be great and thanks for your help.
Asked by: frankr
Two of these in a 4 cubic foot sealed enclosure with heavy fill should be plenty with a Bash 300. You can expect plenty of output and in room response down to the low 30's assuming proper room placement.
Date published: 2012-10-04
  • 2016-02-08T07:18CST
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_264-1118, PRD, sort_recentQuestionsFirst
