Peerless 830668 10" Paper Cone SLS Subwoofer
Brand:|Model: 830668|Part # 264-1110
The Peerless SLS Series combines high quality performance with an affordable design.
List Price$98.99
You Save25%
$74.14
Buy 4+$67.83
Part # 264-1110
  • Premium sculpted stamped steel chassis
  • Coated paper cone with rubber edge
  • Shorting ring in magnet system
The Peerless SLS Series combines high quality performance with an affordable design. The SLS drivers are ideal for use in systems with high power handling requirements, and are a logical choice for use with the SDS line of transducers.
  • Nominal Diameter10"
  • Power Handling (RMS)70 Watts
  • Power Handling (max)140 Watts
  • Impedance8 ohms
  • Frequency Response30 to 2,000 Hz
  • Sensitivity87.9 dB 2.83V/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)32 Hz
  • DC Resistance (Re)5.6 ohms
  • Voice Coil Inductance (Le)1.37 mH
  • Mechanical Q (Qms)7.1
  • Electromagnetic Q (Qes)0.59
  • Total Q (Qts)0.55
  • Compliance Equivalent Volume (Vas)2.57 ft.³
  • Mechanical Compliance of Suspension (Cms)0.43 mm/N
  • BL Product (BL)10.42 Tm
  • Diaphragm Mass Inc. Airload (Mms)56.28g
  • Maximum Linear Excursion (Xmax)8.3 mm
  • Surface Area of Cone (Sd)346.4 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter10"
  • Baffle Cutout Diameter8.9"
  • Depth5.24"
  • # Mounting Holes8
  • Sealed Volume1.25 ft.³
  • Sealed F356 Hz
  • Vented Volume3.92 ft.³
  • Vented F328 Hz
  • BrandPeerless
  • Model830668
  • Part Number264-1110
  • UPC844632084164
    (5 Reviews)
  • Weight6.3 lbs.
View similar products to the Peerless 830668 10" Paper Cone SLS Subwoofer
Peerless 830668 10" Paper Cone SLS Subwoofer is rated 4.6 out of 5 by 5.
Rated 5 out of 5 by from Boom goes the subwoofer!I had a 13 year old paradigm sub disintegrate but the amp and the housing was still good. So I looked around but didn't really understand all the ohms and what-have-you so I chatted with a tech who took the specs from my paradigm and recommended this in about 5 minutes.Came in the mail, and it fit perfectly and now I can't wait for age ultron to hit Blu Ray!Great sound and great experience.
Date published: 2015-06-05
Rated 4 out of 5 by from used it to replaceused it to replace a blown sub on a Boston Acustic VR790 tower that I have.Good fit and great sound
Date published: 2014-01-25
Rated 5 out of 5 by from Very Musical SubwooferI am using these in my home stereo system (not in the home theater room). I was looking for something that would be able to reproduce high sound levels while remaining musical. I listen to a broad range of music and have worked a three stereo shops, so I am a bit picky. I was replacing a 15" PA speaker woofer with a 10" to get better accuracy but I didn't want to give up the volume and range.From the TS Parameters, this driver appeared to work well in both sealed and ported enclosures. I opted for the sealed option as size was not a concern and I didn't need much low frequency extension below 30-35Hz.The enclosures that I built are just under 2 cu ft. I initially over stuffed them with polyfill and the bass lacked any boomy warmth. Yes, the word boomy has a negative connotation in audiophile circles but I want to reproduce electronic music as well, and some is intended to boom.After removing 2/3 of the polyfill the speakers were now most efficient at 50hz and 80hz (in my room). The amount of boom was quite sufficient.All that being said, this is an exceptionally good woofer for the price. Since I am using two and crossing them over at 125hz, with an amp rated at 205wpc... they will get as loud as I could want. The xmax is great and the cone excursion is perfect at my maximum listening levels.I could live with these in my home theater system but not the other way around. If you are into music these subs are highly recommended. The enclosure is extremely important though.Here are the photos from the speaker build:https://picasaweb.google.com/116825914925211100681/AudioUpdate#5810470121207904546
Date published: 2012-12-29
Rated 5 out of 5 by from Excellant WooferI took some old B&O Beovox 150's and installed this in each cabinet. I never was happy with the original woofers in these cabinets, but they had a lot of potential. Each of this cabinets have a 10" woofer that is ported towards the floor "speakers have their own stands" a totally insulated interior and a perfect capacity for a 10" woofer. The woofer is crossed over at 100hz and sounds impressive. These cabinets also have a 8" woofer internally sealed from the rest of the cabinet interior which I installed the 8" version with almost the same characteristics, very nice tight mid bass and wonderful low vocals, it is crossed at 100 hz to 800 hz. The cabinets have a 3" soft dome midrange crossed at 800 hz to 5000 hz and a 1" soft dome tweeter crosed at 5000 hz. I changed all the old bi-polar caps out to metallized polypropylene and wow I love these speakers now. The front baffel on these cabinets are curved to compensate for the physics of time delivery from highs to lows. All they needed was decent woofers and modernized crossovers.
Date published: 2010-11-22
Rated 4 out of 5 by from Great SubAppear to be very well built and handle plenty of power. Appreciate the gasket on the back of the frame. Took a chance after running the numbers in programs and Installed 8 (yes 8 as in 4 apiece) in vintage DBX soundfield 1's rather than rebuilding the foam surrounds and am quite satisfied (kept the originals in case I decide to refoam and compare). Programs predicting response are one thing .... critical listening can be quite another. By the way, was very impressed by the way they were packaged. These have protruding surrounds and all the mounting holes had these plastic spacers in them so the surrounds couldn't touch anything in the boxes. Never saw that before. Can reuse them.
Date published: 2010-03-25
  • 2016-02-07T06:47CST
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_264-1110, PRD, sort_mostRecent
I have a 3.66 cu. foot enclosure what length 4" port would be best to tune this woofer in this size of enclosure? What would be the f3? Thank You
Asked by: arky
A 12" long port would provide a tuning frequency of 24 Hz and an F3 of 27 Hz.
Date published: 2016-01-18
Would this work to replace a 10" Boston Micro90PV II home theater downward facing subwoofer in original boston box etc?
Asked by: Grc15
We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2014-12-01
I don't have WinISD installed anymore due to the fact I switched to Apple products.  Does anyone have the ideal sealed and ported box sizes for this sub?  I'm planning on add two cabinets (one driver each) to the rear corners of my room. THANKS!!
Asked by: deewan
The recommended sealed box is 1.25 cubic feet with an F3 of 56 Hz. A vented box would need to be 4 cubic feet with a 4" diameter, 10" long port tube for a tuning frequency of 28 Hz.
Date published: 2014-03-24
Could this woofer be installed in a sealed enclosure, in a down-firing configuration for home theatre?
Asked by: Blackbelt
Yes this will work well both for sealed or for downfiring.
Date published: 2013-04-03
Will this product perform well in an"IB" car install.
The subwoofer will play into the car from the trunk. The trunk will be sealed, with the rear of the sub playing into the trunk, without a box.
Asked by: KolibaSA
Yes this would be a good option for an IB.
Date published: 2013-02-19
  • 2016-02-07T07:28CST
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_264-1110, PRD, sort_recentQuestionsFirst
