Peerless 830667 8" Paper Cone SLS Subwoofer
Brand:|Model: 830667|Part # 264-1102
The Peerless SLS Series combines high quality performance with an affordable design.
List Price$88.99
You Save26%
$66.25
Buy 4+$62.10
Part # 264-1102
  • Premium sculpted stamped steel chassis
  • Coated paper cone with rubber edge
  • Shorting ring in magnet system
The Peerless SLS Series combines high quality performance with an affordable design. The SLS drivers are ideal for use in systems with high power handling requirements, and are a logical choice for use with the SDS line of transducers.
  • Nominal Diameter8"
  • Power Handling (RMS)110 Watts
  • Power Handling (max)220 Watts
  • Impedance8 ohms
  • Frequency Response36.5 to 2,000 Hz
  • Sensitivity87.2 dB 2.83V/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)42 Hz
  • DC Resistance (Re)5.5 ohms
  • Voice Coil Inductance (Le)0.78 mH
  • Mechanical Q (Qms)5.7
  • Electromagnetic Q (Qes)0.75
  • Total Q (Qts)0.66
  • Compliance Equivalent Volume (Vas)0.93 ft.³
  • Mechanical Compliance of Suspension (Cms)0.41 mm/N
  • BL Product (BL)8.26 Tm
  • Diaphragm Mass Inc. Airload (Mms)34.78g
  • Maximum Linear Excursion (Xmax)8.41 mm
  • Surface Area of Cone (Sd)213.8 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.44"
  • Baffle Cutout Diameter6.97"
  • Depth4.39"
  • # Mounting Holes8
  • Sealed Volume0.72 ft.³
  • Sealed F358 Hz
  • Vented Volume2.09 ft.³
  • Vented F328 Hz
  • BrandPeerless
  • Model830667
  • Part Number264-1102
  • UPC844632084126
    (4 Reviews)
  • Weight5.95 lbs.
View similar products to the Peerless 830667 8" Paper Cone SLS Subwoofer
Peerless 830667 8" Paper Cone SLS Subwoofer is rated 4.5 out of 5 by 4.
Rated 5 out of 5 by from Great Woofer/SubI bought this as a replacement for an older foam surround woofer. I like the rubber surround feature. It dropped in nicely and once connected and sealed, it performs beautifully. This unit was probably designed for a vented cabinet, but I'm using it in a sealed acoustic suspension setup. It still has the deep bass, but it needs equalized to bring it up to matching levels. Power handling is above the woofer I replaced, so that's no problem. It has a tight response. The crossover point is at 600hz, which is no problem either as this woofer has response to 2khz, according to specs. I'm very pleased.
Date published: 2014-05-12
Rated 5 out of 5 by from No purchased yet but very interestedCame across a build for the "Redneck Subwoofer" that sounds so intriguing, and so low budget that it's almost silly.http://www.transcendentsound.com/Transcendent/Subwoofer.htmlI'm going to give it five stars across simply on the merits of half a dozen reviews of this sub project that I've read.
Date published: 2013-12-02
Rated 4 out of 5 by from Nice subwooferI'm using this speaker in an H frame OB project. It performs nice in this application although its a bit X-max limited. Other than that its a nice quality speaker true to the Peerless brand.
Date published: 2012-11-19
Rated 4 out of 5 by from Big Sound Great Value!I'm very impressed with this little sub. I made a 1.6 cu. ft. enclosure with a 3" x 6.75" long flared port. F3 of 33Hz, with +2db bump. I'm powering it with a Bash 300 plate amp. and the results are very musical without being boomy. It has enough punch to shake things up, more than you might expect from an 8" subwoofer. You will be very pleased with the Peerless SLS for value and performance. Cheers!
Date published: 2010-11-06
  • 2016-02-11T06:37CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_264-1102, PRD, sort_mostRecent
Hi ! I need to change my 2 Peerless 831483 for my Genelec 1092A. I think the features are the same. Can i use this speaker ?
Asked by: Sparte303
We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2016-01-12
I will be using these speakers as replacements in  an infinity cs 3007 speaker tower. Will they work correctly ?
Asked by: Paul TTT
Date published: 2015-10-09
What size box would you recommend for in a vehicle? I am looking at doing two of these in my gti. Will be building 2 sealed boxes for them So each sub has its own box. Will .25 ft work? Need to know what internal volume it needs. Thanks.
Asked by: The Hoff
0.25 will work but if you can get closer to 0.5 heavily stuffed you will have a little better bottom end.
Date published: 2015-05-12
Would this driver be suitable for infinite baffle use?
Asked by: AudioGMan
Yes this will work well for an IB application.
Date published: 2015-02-03
Hi also following the transcendent sound story but wondering about the sealed box down firing. I am a novice and wondered about this and the gap needed to the floor etc. Any input welcome. Thanks
Asked by: MarkW
I usually recommend a gap that is 1/4 to 1/3 the diameter of the woofer for a downfiring application.
Date published: 2014-10-10
Can I use this in a "3-way" system with the woofer and a midrange crossed over at 1600? I am a little wary about using a "subwoofer" as opposed to a woofer.
Asked by: Captain Paintball
I would not recommend crossing this any higher than about 800 Hz.
Date published: 2014-08-18
  • 2016-02-11T07:12CST
  • co_hasquestionsanswers, tq_11
  • loc_en_US, sid_264-1102, PRD, sort_recentQuestionsFirst
