Peerless 830657 6-1/2" Paper Cone SDS Woofer
Brand:|Model: 830657|Part # 264-1088
The Peerless Superior Dynamic Sounds (SDS) Series provides the lowest cost/highest-quality woofers in the industry today.
List Price$34.99
You Save38%
$21.70
Buy 4+$19.98
Part # 264-1088
  • Premium sculpted stamped steel chassis
  • Coated paper cone with rubber edge
  • Smooth, extended response
The Peerless Superior Dynamic Sounds (SDS) Series provides the lowest cost/highest-quality woofers in the industry today. The SDS woofers are characterized by their very smooth frequency response all the way into the midrange, with low distortion and consistent off-axis performance. Applying the best in Danish engineering, but manufactured to be very affordable, these audio transducers are ideal for use in small surround sound systems and other hi-fi applications.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)60 Watts
  • Power Handling (max)110 Watts
  • Impedance8 ohms
  • Frequency Response40 to 4,000 Hz
  • Sensitivity88.2 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)45 Hz
  • DC Resistance (Re)6 ohms
  • Voice Coil Inductance (Le)0.38 mH
  • Mechanical Q (Qms)2.74
  • Electromagnetic Q (Qes)0.55
  • Total Q (Qts)0.46
  • Compliance Equivalent Volume (Vas)1.09 ft.³
  • Mechanical Compliance of Suspension (Cms)1.1 mm/N
  • BL Product (BL)5.98 Tm
  • Diaphragm Mass Inc. Airload (Mms)11.5g
  • Maximum Linear Excursion (Xmax)3.46 mm
  • Surface Area of Cone (Sd)141 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter7.17"
  • Baffle Cutout Diameter5.71"
  • Depth2.72"
  • # Mounting Holes6
  • Sealed Volume0.4 ft.³
  • Sealed F389 Hz
  • Vented Volume1.27 ft.³
  • Vented F345 Hz
  • BrandPeerless
  • Model830657
  • Part Number264-1088
  • UPC844632084058
  • Product CategoryWoofers
  • Weight2 lbs.
View similar products to the Peerless 830657 6-1/2" Paper Cone SDS Woofer
Hi, I would like to replace my old Peerless woofers (165WF 33/100 PPB 8 ohm model: 831599) with the newer Peerless model 830657- are these compatible?
If not could you please recommend a suitable replacement?tks!
Asked by: Bateau
I was not able to find much information at all regarding the 831599 woofer to compair the two. What type of enclosure/design is the original in?
Date published: 2015-10-19
Can use this driver with a couple of passive radiator SDS 5-1/4?
Active 1 X 830657 Passive 2 X 830880
Asked by: jbarale
I would only use one of the radiators. You want to have an even cone movement.
Answered by: Booth man
car audio application
would this be suitable for a mid range and what of the T/S parameters would tell me that it is.
Asked by: T MAC
t/s deals mostly with bass,, paper gets wet and deforms faster over time in cars,,car metal pulls current out of the wiring by inductance dulling and reducing volume 4 ohm coils are used in autos to get more sound and these drivers are deeper than most doors allow ,, already tried them.
Answered by: digitalhaven 53
Whats a good vented and or sealed box sizes?
Asked by: Chrome
LOOK AT THE SPECS FOLLOW THE BOX FORMULA'S FOR MAX BASS PORT IT, VENT IT TRANSMISSION LINE IT, HORN LOAD IT ETC...BUT IF YOU HAVE A SUB LOW FREQUENCY EXTENSION ... SEAL STUFF IT FOR BEST ATTACK AND RESPONSE IN .5 TO .65 CUFT ... SET THE SUB CROSSOVER TO THE AUDIBLE LOW END OF YOUR PERSONAL TASTE AND ENJOY YOUR LABORS!
Is there any way to shield this so I can put it close to a TV?
Asked by: rodneycdavis
While some DIYers have had success installing bucking magnets on drivers so that they can be placed closer to CRT televisions, we would recommend instead buying a shielded driver.
Answered by: JoeW
  • 2016-02-08T07:18CST
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_264-1088, PRD, sort_recentQuestionsFirst
