Peerless 830656 5-1/4" Paper Cone SDS Woofer
Brand:|Model: 830656|Part # 264-1078
The Peerless Superior Dynamic Sounds (SDS) Series provides the lowest cost/highest-quality woofers in the industry today.
List Price$25.99
You Save31%
$17.90
Buy 4+$15.08
Part # 264-1078
  • Premium sculpted stamped steel chassis
  • Coated paper cone with rubber edge
  • Smooth, extended response
The Peerless Superior Dynamic Sounds (SDS) Series provides the lowest cost/highest-quality woofers in the industry today. The SDS woofers are characterized by their very smooth frequency response all the way into the midrange, with low distortion and consistent off-axis performance. Applying the best in Danish engineering, but manufactured to be very affordable, these audio transducers are ideal for use in small surround sound systems and other hi-fi applications.
  • Nominal Diameter5-1/4"
  • Power Handling (RMS)60 Watts
  • Power Handling (max)110 Watts
  • Impedance8 ohms
  • Frequency Response50 to 5,000 Hz
  • Sensitivity84.5 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)57 Hz
  • DC Resistance (Re)6.1 ohms
  • Voice Coil Inductance (Le)0.37 mH
  • Mechanical Q (Qms)3.6
  • Electromagnetic Q (Qes)0.7
  • Total Q (Qts)0.59
  • Compliance Equivalent Volume (Vas)0.31 ft.³
  • Mechanical Compliance of Suspension (Cms)0.83 mm/N
  • BL Product (BL)5.36 Tm
  • Diaphragm Mass Inc. Airload (Mms)9.3g
  • Maximum Linear Excursion (Xmax)3.46 mm
  • Surface Area of Cone (Sd)86.6 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.98"
  • Baffle Cutout Diameter4.61"
  • Depth2.23"
  • # Mounting Holes6
  • Sealed Volume0.2 ft.³
  • Sealed F399 Hz
  • Vented Volume0.58 ft.³
  • Vented F348 Hz
  • BrandPeerless
  • Model830656
  • Part Number264-1078
  • UPC844632084003
  • Product CategoryWoofers
    (12 Reviews)
  • Weight1.65 lbs.
View similar products to the Peerless 830656 5-1/4" Paper Cone SDS Woofer
Peerless 830656 5-1/4" Paper Cone SDS Woofer is rated 4.5 out of 5 by 12.
Rated 4 out of 5 by from So far so good.I bought these to replace the four on my rear deck of my 00 750il. They fit fine. I still need more power to get a quality sound. I will be changing my amp next.
Date published: 2015-03-05
Rated 5 out of 5 by from excellent replacement.i brought these speakers for my wife's 2001 740il rear deck. The originals were rotted out. if you know anything about the E38, it is hard to find aftermarket subs to fit the rear deck. i just had to drill new holes in the deck and use speaker gasket tape to help with a better seal. what a surprise when i fired the system up. the bass response was excellent. Don't need a box in the trunk now. For the price you can't beat these.
Date published: 2014-09-21
Rated 2 out of 5 by from Not the best choise for E38 bmwThis is not what you expect to hear from the rear deck of E38 BMW. Ofcourse you get what you pay for (original are $100 each), but this specific speakers CAN NOT substitute OEM rear deck speackers on this car at all. Not too much problems with installing as mentioned in previous reviews, took me 2 hours to change all of them, but will keep looking for something better.
Date published: 2014-05-16
Rated 5 out of 5 by from I would recommend these Woofers, However..If you are going to be installing these in the rear desk of a BMW E38, be prepared to cut the deck (4 times) to fit these speakers of which do not fit OEM. Keep in mind there is limited space to work on the rear deck, unless you plan on removing the rear deck, which is a big job in itself! I should have contacted parts-express first and let them tell me what fits E38 OEM. They are not exactly 5 1/4 and have a unique baffle hole.. I chose not to cut anything at all and built a small bridge for the speaker covers so not as to have the speaker covers make contact with speakers.. I hope this helps!
Date published: 2013-09-09
Rated 5 out of 5 by from Outstanding speaker for the money!Bought 4 of these for my 1998 BMW 750IL. Factory BMW replacement speakers are around $100 each. These are a near perfect fit in the rear subwoofer deck and approx $17 each. Original speakers had 4 screw holes, these have 6 that don't match original holes, just had to put 4 notches in the speakers (on mounting area) to accomodate the original screw locations and also put a thin foam seal under each speaker mount area. Anyway, these sound awsome compared to the original speakers that were in my car. Factory amp puts a max of 50 watts into each speaker. Great bass response and sound, very crisp. Mounted in the enclosure they are sealed, not ported. Quite an excellent value for the money and I am very satisfied. If you have a E38 BMW and want to replace your factory subs, these are great! You will be happy!
Date published: 2012-12-30
Rated 4 out of 5 by from Works well in BMW E38 DSP rear deck boxInstalled in my E38 BMW's rear deck. The OEM speakers are over $100 each, 4 were needed. I had to trim a very small amount of plastic to fit the center speakers. They work well, sound good. They add the bass that was missing.
Date published: 2012-10-23
  • 2016-02-06T07:03CST
  • co_hasreviews, tv_0, tr_12
  • loc_en_US, sid_264-1078, PRD, sort_mostRecent
Hi! Can i use this to replace the woofer of my wharfdale diamond 9.1's? Thanks!
Asked by: bongski
We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-12-30
Is this speaker shielded?
Asked by: Thanks
No this speaker is not shielded.
Date published: 2015-11-30
Please confirm this sub  woofer is the correct (inexpensive) replacement for a BMW 2001 740 (E 38) that fit under the parcel shelf. thank you. Is there a better match? Thank you.
Asked by: boppa
Date published: 2015-11-09
If I used the Panasonic wire terminal with mid bass/tweeter crossover set at 5500, would this speaker not produce any sound between the 5000Hz and 5500Hz where the tweeter kicks in?
Asked by: Bcboyz86
The filter does not brick-wall the frequencies. Both the woofer and tweeter will have shallow roll-offs above and below their crossover points, which will cause a blend between the two. There will not be a gap between 5,000 and 5,500 Hz.
Date published: 2015-08-04
what would be the smallest enclosure i could stuff this into to get a tune to about 150-200 Hz? could i achieve this in a box .07 cu ft? say a 6" x 7" x 3" interior dimension box?
Asked by: Bcboyz86
Yes you can easily reach 150-200 Hz in this volume sealed. The F3 of this volume is about 100 Hz.
Date published: 2015-07-30
I need replacements for the M&K satellites S-1A Any suggestion ? Thanks
Asked by: superhomes
Date published: 2015-07-06
  • 2016-02-06T08:11CST
  • co_hasquestionsanswers, tq_18
  • loc_en_US, sid_264-1078, PRD, sort_recentQuestionsFirst
