Peerless 830452 10" XLS Subwoofer
Brand:|Model: 830452|Part # 264-1108
This series of state-of-the-art subwoofers continues to enhance Peerless's reputation for delivering the highest quality components for bass.
List Price$258.99
You Save25%
$194.67
Buy 4+$178.11
Part # 264-1108
  • 12.5 mm of linear excursion
  • Thick Nomex cone
  • Cast aluminum frame
  • Flat spider and HD rubber half roll surround
  • Massive stacked magnet
This series of state-of-the-art subwoofers continues to enhance Peerless's reputation for delivering the highest quality components for bass. Called the XLS—for "Extra Long Stroke"—these audio transducers add more excursion while eliminating distortion. The XLS line features a strong yet attractive cast frame, Nomex cone, flat spider, and generous under-spider venting. The magnet system incorporates multiple distortion-canceling fixtures.
  • Nominal Diameter10"
  • Power Handling (RMS)150 Watts
  • Power Handling (max)300 Watts
  • Impedance4 ohms
  • Frequency Response19 to 700 Hz
  • Sensitivity86.6 dB 2.83V/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)22 Hz
  • DC Resistance (Re)3.6 ohms
  • Voice Coil Inductance (Le)0.99 mH
  • Mechanical Q (Qms)3.86
  • Electromagnetic Q (Qes)0.24
  • Total Q (Qts)0.23
  • Compliance Equivalent Volume (Vas)2.36 ft.³
  • Mechanical Compliance of Suspension (Cms)0.39 mm/N
  • BL Product (BL)16.75 Tm
  • Diaphragm Mass Inc. Airload (Mms)136.6g
  • Maximum Linear Excursion (Xmax)12.5 mm
  • Surface Area of Cone (Sd)349.7 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter10.59"
  • Baffle Cutout Diameter9.4"
  • Depth4.88"
  • # Mounting Holes6
  • Sealed Volume0.12 ft.³
  • Sealed F395 Hz
  • Vented Volume0.24 ft.³
  • Vented F365 Hz
  • BrandPeerless
  • Model830452
  • Part Number264-1108
  • UPC844632084157
    (4 Reviews)
  • Weight14.1 lbs.
View similar products to the Peerless 830452 10" XLS Subwoofer
Peerless 830452 10" XLS Subwoofer is rated 5.0 out of 5 by 4.
Rated 5 out of 5 by from Delivers on very low bass!The cabinet is 1.3 cu. ft. and it has a 3 inch flared port with a 13" tube. The amp is a Dayton SA250 250 watts plate amplifier. The Peerless XLS 10 inch subwoofer in this instance has a very low end extension, and is very smooth, and high fidelity with the rest of my Onkyo HT-RC560, and custom satellites. It seems to blend very well into the rest of the speakers which are crossed over at 120 hz for the mains and surrounds, and 150 hz for the center and surround backs. It took some time that is a couple of days to free up the compliance of the suspension. My subwoofer is very heavy, and on carpet spikes, so coupling to the floor is fairly good. I think that's important even for lower volumes. The previous driver was the Peerless paper cone 10 inch which wasn't getting down to sub audible. This Nomex cone 10 inch XLS does, and incidentally, the mains and surrounds have the Peerless 6.5 inch Nomex cone woofer. The amp is set for allowing all (180 hz) and gain is just a bit past 50%. About the appearance of the woofer. The frame is excellent, casting, and it looks like it means business. The drivers physical appearance is very clean and rugged.
Date published: 2015-04-13
Rated 5 out of 5 by from Great Woofer!I needed a robust woofer to blend with a pair of Focal 7" midbass in my truck. The box is 2.1 ft3 tuned to 36hz with a Zapco C2k-6.0 bridged. This way more power than recommended ( within reason) the XLS's haven't complained. The previous drivers (in the same custom box) went low, could take an insane amount of power and could survive nuclear winter. True car audio Subs that weighed 24lbs each. They just were not smooth or even musical above 60 hz. More one note wonders than anything.Enter the XLS 10's.These woofers did an excellent job blending with my doors (my wife noticed a huge improvement). Don't expect huge SPL numbers! They do play low and loud but I wouldn't subject them to Dubstep for hours on end. Well built, reasonable sensitivity, priced under $200 each. My other option was to use woofers made in Israel, which are incredible, but double the price.The frame took a larger hole than required by the other 10" woofers I tried. Dual 4 ohm voice coils would have been nice.
Date published: 2014-11-17
Rated 5 out of 5 by from Excellent Subwoofer for a 2.1 bedroom systemI was buying 4 of the Celestion 5" full range woofers for an acoustic cabinet build and was looking for other items I might need for other builds. I found this Peerless 10" XLS Sub at a killer price and quickly snapped one up for use with a Dayton Audio 2.1 Plate Amplifier that I had purchased back in May of last year. I built a 1 cuft. cube for the sub and since this speaker reaches down to 20Hz I tuned it to about 30Hz. I wanted a deep reach as opposed to loud. Mission accomplished, I matched the system up with some small JBL speakers I've had for some time and hooked this system up to our bedroom TV. WOW, I just finished the build last night so the speaker is not fully broken in yet but the sound is wonderful. This speaker looks as good as it sounds, the cast frame is solid and has a nice looking mounting ring, the rubber surround and speaker face are agressive looking. Only thing about this speaker is that it does not have any gasket on the mounting side of the speaker ring so make sure to have some on hand when doing your build.
Date published: 2013-01-19
Rated 5 out of 5 by from Great Subwoofer!!Used this subwoofer with the Peerless passive radiator and a 250 watt PE plate amp. This thing can dish out loads of deep bass all night long. It is a very efficient and tough subwoofer. Would like to try this sub in a ported box, when I get a chance.
Date published: 2012-03-24
  • 2016-02-08T06:28CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_264-1108, PRD, sort_mostRecent
What thickness of gasket should I use? Is there a gasket specific for this driver that I can acquire?
Asked by: Pdavid
There are no specific gaskets for this woofer but our speaker gasketing tape would work very well.http://www.parts-express.com/parts-express-speaker-gasketing-tape-1-8-x-3-8-x-50-ft-roll--260-540
Date published: 2016-01-14
What PR would you recommend for this driver in a 1.6 cu. ft. box or would it work in same size box sealed?
Asked by: PAH64
Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531
Answered by: MattW
Date published: 2015-10-08
The manufacturer spec sheet shows a bizarre -10db dip around 25hz...  Anyone have thoughts why this would be?  measurment room standing waves possibly?  has anyone noticed this with a sealed enclosure with their own use?
Asked by: DonkeyB
Anything below 200-400 Hz will be entirely room or measurement related, so free air anechoic measurements will not be 100% accurate below these frequencies depending on the room size used for testing. Chances are this driver was measured at both near and far field and then spliced, so this could be a phase or reflection related anomaly with the microphone.
Date published: 2015-04-14
How would this sub do in a vented 1.3cuft box tuned to 32hz? Auto application
Asked by: Jake0528
Answered by: MattW
The optimum cabinet size listed on the description...is it in error by one decimal place? Is Vented Optimum 1.2 cu.ft.?
Asked by: EdCase
This volume is optimal, that is not a typo.
Do you have a diagram for the peerless 830452 10 inch XLS subwoofer coupled with spa250?
Asked by: Jimb
  • 2016-02-08T07:18CST
  • co_hasquestionsanswers, tq_9
  • loc_en_US, sid_264-1108, PRD, sort_recentQuestionsFirst
