Peavey XR 8600D Powered Box Mixer 600W x 2
Brand:|Model: XR 8600D|Part # 248-798
Continuing in the tradition of the world's most reliable mixer-amp boxes is Peavey's new XR 8600D features new & improved low noise mic preamps, multi-point clip sampling, and a new subsonic filter to prevent low-frequency power robbing.
Part # 248-798
  • 10 line inputs
  • 3-band equalization on each channel
  • Monitor send on each channel
  • 25 dB pad: channels 1-6
  • Dual main or main/monitor power amp mode switch
  • Dedicated 7-band EQ for main/monitors with FLS™
  • DSP-based effects
The XR 8600 powered mixer include many of the latest technological developments from Peavey engineering. Incorporating a pair of 600 watt amplifiers, dual 7-band EQ, digital effects, FLS® (Peavey's award-winning Feedback Locating System), DDT™ speaker protection and a host of other features, these compact powered mixers are perfect for any application. Peavey item 03003160.
Specifications: • Output power: 300 watts RMS x 2 (8 ohms), 500 watts RMS x 2 (4 ohms)/ 360 watts peak x 2 (8 ohms), 600 watts peak x 2 (4 ohms) • Frequency response: 20 Hz - 20 kHz, +0 dB/-1 dB @ rated power • THD: <0.01% @ rated output  @ 1 kHz • DDT Dynamic range: >26 dB • DDT Max distortion: <0.5% THD for 6 dB overload, 1% THD for 20 dB overload • Hum and Noise: 95 dB below rated power level (500 watts) • Damping factor: >100 @ 1 kHz, 4 ohms • Input sensitivity: 2.5V RMS for 500 watts @ 4 ohms • Input impedance: 8.25k ohms • Dimensions: 21" W x 11.75" H x 12.375" D • Weight: 23.8 lbs.
PRODUCT SPECIFICATIONS
  • Mixer TypeAnalog
  • Special FeaturesDigital Effects
  • XLR Mic Inputs10 to 15
  • BrandPeavey
  • ModelXR 8600D
  • Part Number248-798
  • UPC014367153231
  • Product CategoryPowered Mixers
    (2 Reviews)
  • Weight40 lbs.
View similar products to the Peavey XR 8600D Powered Box Mixer 600W x 2
in the Powered Mixers product category.
