BONUS ITEM INCLUDED
248-8110_ALT_0
Peavey Versarray 218 Dual 18" Subwoofer Black
Brand:|Model: Versarray 218|Part # 248-8110
The Versarray 218 (black) features an incredible 4,800-watt program rating is made possible by Kevlar®-impregnated cones that increase strength and minimize distortion.
ORDER TODAY
Ships in 7-10 Business Days
ShippingTRUCK ONLY
$2,399.99
Peavey Baseball Cap
Qty: 1Part # 520-302
List Price:$19.99
*Domestic US orders only
Part # 248-8110
  • Full-power low-frequency response down to 38 Hz
  • Two 18" vented Lo Max® woofers
  • 4/8 ohms selectable
  • Two Neutrik® 4-pin Speakon® inputs in parallel
  • One Neutrik® 8-pin Speakon® input
  • One Neutrik® 4-pin Speakon® thru imput (use with 8-pin input)
  • Patented UniVent vented cooling system
The Versarray 218 (black) features an incredible 4,800-watt program rating is made possible by Kevlar®-impregnated cones that increase strength and minimize distortion, as well as polymide-impregnated fiberglass formers, die-cast aluminum frames and 4-inch diameter edge-wound voice coils with solderless, diffusion-welded OFHC copper leads. The Versarray 218 also features the Peavey UniVent™ venting system, which uses an exclusive process to literally pump cool outside air through the enclosure, maintaining cool operating temperatures, increasing reliability and reducing power compression under heavy continuous-drive conditions. With premium 13-ply Baltic birch construction, a durable acrylic polyurethane finish and a 16-gauge, powder-coated perforated metal grille, the Versarray 218 is built to endure years of heavy use, and tilt-back 4" casters allow easy transport and setup along the way. Input connections are made via two 4-pin Neutrik® jacks in parallel, or an 8-pin Neutrik with a 4-pin Neutrik thru jack for bi-amping. An optional bolt-on Ground Stack Kit allows users to mount up to three Versarray 112 enclosures with full articulation. Peavey item 00584470.
Specifications: • Power handling: 2,400 watts continuous, 4,800 watts program, 9,600 watts peak • Frequency response: 45 Hz to 1.5 kHz (anechoic environment) • Weight: 215.00 lbs. (97.52 kg) • Width packed: 28.50" (72.39 cm) • Depth packed: 45" (114.30 cm) • Height packed: 28.5" (72.39 cm).
  • ConfigurationSubwoofer
  • Woofer Size18"
  • BrandPeavey
  • ModelVersarray 218
  • Part Number248-8110
  • UPC0014367125665
  • Weight215 lbs.
View similar products to the Peavey Versarray 218 Dual 18" Subwoofer Black
