Peavey Versarray 112 Line Array Speaker System Black
Brand:|Model: Versarray 112|Part # 248-8108
The Versarray 112 (black) ribbon-driver line array utilizes a high-performance, lightweight 12" Neo Black Widow® woofer featuring a dual 4" flat wound voice coil with a neodymium magnet structure in a 13-ply Baltic birch enclosure.
Part # 248-8108
  • 2-way Bi-Amp Ribbon Line Source Array SR System
  • 12" Neo Black Widow 4" VC Woofer
  • 1,000 watt program, 2,000 watt peak power handling
  • Ribbon Tweeters with Neo magnet and composite material sandwich ribbon
  • 90° H by 15° V coverage pattern (per one cabinet)
  • Easy aiming angle adjustment rigging system
  • Angle adjustable in 2 1/2 degree increments from 0 to 15 degrees, total angle between adjacent cabi
The Versarray 112 (black) ribbon-driver line array utilizes a high-performance, lightweight 12" Neo Black Widow® woofer featuring a dual 4" flat wound voice coil with a neodymium magnet structure in a 13-ply Baltic birch enclosure. The Versarray 112 offers extreme versatility and performance in modular coverage of small- to medium-sized venues and is intended for use with Versarray 118 or 218 subs. Sound Guard™, Peavey's proprietary protection circuitry, provides long- and medium-term driver overload protection without impairing musical transients or dynamics. Peavey item 03008650.
Specifications: • Usable low frequency limit (-10 dB point): 85 Hz (with processing) • Power handling: Low frequency section: 500 W continuous, 1,000 W program, 2,000 W peak; High Frequency section: 80 W continuous, 160 W program, 320 W peak • Maximum sound pressure level (1 meter): Low frequency section: 123 dB SPL continuous, 129 dB SPL peak, 130 dB SPL measured peak; High frequency section: 118 dB SPL continuous, 124 dB SPL peak, 130 dB SPL measured peak • Impedance (Z): Low frequency: Nominal 8.0 ohms, Minimum 6.5 ohms.
  • ConfigurationLine Array
  • Woofer Size12"
  • BrandPeavey
  • ModelVersarray 112
  • Part Number248-8108
  • UPC014367600742
  • Weight57.3 lbs.
View similar products to the Peavey Versarray 112 Line Array Speaker System Black
