248-8156_ALT_0
248-8156_ALT_1
248-8156_ALT_2
Peavey SP 218 Dual 18" PA Subwoofer System
Brand:|Model: SP 218|Part # 248-8156
The SP® 218 uses two custom-designed large excursion 18" Pro Rider® Black Widow® woofers that can produce incredible deep bass with very low distortion handling up to 4,800 watts of peak power.
Part # 248-8156
  • Two 18" Pro Rider®Black Widow® woofers with Kevlar®/carbon fiber cones
  • Field-replaceable baskets, flat-wound 4" voice coils, and cast-frame baskets
  • Baltic birch enclosure
  • Steel grill
Frequently Bought Together
The SP® 218 subwoofer is designed for large systems and works perfectly with the Peavey SP® line of enclosures. The SP® 218 uses two custom-designed large excursion 18" Pro Rider® Black Widow® woofers that can produce incredible deep bass with very low distortion handling up to 4,800 watts of peak power. If your looking for amazing lows and thunderous bottom end to accompany your SP® enclosures, this dual 18" 4 ohm cabinet will deliver the goods sonically. The solid cabinetry construction of birch ply is carpet-covered and has an extra heavy-duty grill for ruggedness. Peavey item 03586570.
Specifications: • Frequency response: 51 Hz-300 Hz; -10 dB point: 36 Hz • Sensitivity: 100 dB 1W/1m • Power: 2,400 watts program; 4,800 watts peak • Impedance: 4 ohms • Dimensions: Width 21.625", Depth 30", Height 42.375" • Weight: 121.4 lbs.
  • ConfigurationSubwoofer
  • Woofer Size18"
  • BrandPeavey
  • ModelSP 218
  • Part Number248-8156
  • UPC014367106350
  • Weight164 lbs.
View similar products to the Peavey SP 218 Dual 18" PA Subwoofer System
