299-462_ALT_0
299-462_ALT_1
Peavey RX14 1" Compression Driver with 1-3/8"-18 TPI 80 degree Conical Horn
Brand:|Model: RX14|Part # 299-462
Peavey's RX14 is a 1" compression driver designed with a pure titanium diaphragm and 1.4" Kapton voice coil for greater power handling. It's paired with a conical horn through this Parts Express exclusive buyout, and you can save up to 50% off the original retail price!
Part # 299-462
  • 1" screw-on compression driver with removable conical horn
  • Pure titanium diaphragm and high-temp Kapton former
  • High 104 dB sensitivity with great power handling
The Peavey RX14 1" compression driver is known for excellent driver performance, reliability, and power handling. The voice coil is a copper clad aluminum wire wound on a Kapton high temperature coil former. The one-piece titanium diaphragm reduces the amount of moving mass, extending the high frequency response of the driver. Ferrofluid cooling is used for improved reliability and smoother frequency response.
An 80° conical horn is pre-attached to the 1-3/8"-18 TPI threads for extremely controlled dispersion and high output, and can be removed in favor of a different horn for different dispersion patterns. Save up to 50% off on this popular horn driver through this Parts Express factory buyout! Quantities are limited.
Specifications: • Throat diameter: 0.938" (23.8 mm) • Nominal impedance: 8 ohms • DC Resistance: 6.8 ohms • Power capacity 1,000 Hz to 20,000 Hz: 30 watts continuous, 60 watts program, 120 watts peak • Sensitivity: 104 dB SPL 1W/1m • Frequency response: 1,500-20,000 Hz • Recommended crossover: 1,800 Hz at 12 dB/octave • Lowest recommended crossover: 2,000 Hz at 12 dB/octave • VCdia: 1.4" (34.4 mm) • Dimensions: 3.54" (90 mm) diameter, 2.40" (61 mm) depth, Cutout: 2.375" • Center-to-center screw spacing on waveguide: 2.5" • Threads: Standard 1-3/8"-18" • Weight: 2.26 lbs. (1.024 kg).
  • Mounting Type1-3/8"-18 TPI
  • Exit Diameter1"
  • Diaphragm MaterialTitanium
  • Impedance8 ohms
  • Power Handling (RMS)30 Watts
  • BrandPeavey
  • ModelRX14
  • Part Number299-462
  • UPC0014367136937
  • Product CategoryHorn Drivers
    (3 Reviews)
  • Weight2.4 lbs.
View similar products to the Peavey RX14 1" Compression Driver with 1-3/8"-18 TPI 80 degree Conical Horn
in the Horn Drivers product category.
