BUYOUT
299-460_ALT_0
299-460_ALT_1
299-460_ALT_2
299-460_ALT_3
299-460_ALT_4
299-460_ALT_5
299-460_ALT_6
Peavey Rockola 6.5 6.5" 2-Way Bookshelf Speaker
Brand:|Model: Rockola 6.5
Choose the Peavey Rockola 6.5 for small format monitoring and for background music systems in bars and restaurants. A full range 6-1/2" speaker is loaded into a water resistant cabinet (grill not included) that features multiple mounting points. Save up $70 off through this exclusive factory buyout.
List Price$149.99
Regular Price$119.00
You Save76%
Sale Price
$29.00
Part # 299-460
  • Full range sound reinforcement in a small package
  • Eight threaded inserts for a variety of mounting options
  • Water resistant cabinet (grill not included)
  • Made in the USA
Peavey built the Rockola® 6.5 6-1/2" speaker as a small format, full range speaker that is perfect for any application, from foreground music and monitoring to speech reinforcement. The Rockola has high fidelity sound characteristics, with great clarity, which is ideal for background music systems in bars, taverns, arenas, lounges, arcades or anywhere multi-channel, multi-speaker sound systems are required.
Five 1/4"-20 top-mounted inserts, two side-mounted 1/4"-20 inserts, and one bottom-mounted 1/4"-20 insert are built in for wall or ceiling mounting, flown, or stacked in arrays (additional hardware required). Additionally, the water resistant cabinet (grill not included) is designed to work with Peavey Versamount speaker mounting systems. Screw down speaker terminals allow for a quick, secure connection to an amplifier. Sold individually.
Save up to $70 off the original retail price through this Parts Express exclusive buyout! Quantities are limited. Made in the USA.
Specifications: • Power handling: 50 watts RMS • Frequency response: 80-7,000 Hz (-10 dB) • Sensitivity: 86 dB at 1W/1m • Impedance: 8 ohms • Dimensions: 11.5" H x 7.5" W (front) tapered to 3.25" W (back), 6.5" D.
  • Input Rating8 ohm
  • Woofer Diameter6-1/2"
  • ConfigurationFull-range
  • ColorBlack
  • BrandPeavey
  • ModelRockola 6.5
  • Part Number299-460
  • UPC848864007786
  • Product CategoryBookshelf Speakers
    (6 Reviews)
  • Weight8.1000 lbs.
View similar products to the Peavey Rockola 6.5 6.5" 2-Way Bookshelf Speaker
in the Bookshelf Speakers product category.
Peavey Rockola 6.5 6.5" 2-Way Bookshelf Speaker is rated 4.5 out of 5 by 6.
Rated 4 out of 5 by from Peavey RockolaSuper sound but doesn't come with a grill. Excellent choice for my garage. Good size and easy to mount.
Date published: 2015-04-17
Rated 5 out of 5 by from Nice little speakers. Easy to customizeI bought 12 of these. It was easy to install a metal grill . The face of these are aluminum. I used some self tapping metal screws with 1/4 20 nuts for stand offs. Also used a cordless drill with 1" paddle bit to install 2 speakon connectors in each. I kept the terminal plate, and rewired this to make 16 ohm pairs. Very simple to make mounting plates for rigging, with the many T nuts that are built in the enclosure.I think i will purchase 12 more, before these are gone. I am using these for delay zones and small arena sound systems. I made some rigging out of aluminum to hang off of truss. I dont mind the high end cut off, not noticeable at my age.. LOL
Date published: 2015-03-19
Rated 4 out of 5 by from EXCELLENTwould give five stars if mounting brackets provided.
Date published: 2015-03-09
Rated 5 out of 5 by from Very Nice Unit!I just received two of these today as i took the advantage of the wicked deal! But two slight issues, they have tons of leaks which is easily fixed with gasketing tape and the driver is a woofer so i am running tweeters within the same enclosure and create a two-way system. Other than that very well done by Peavey!!
Date published: 2014-09-24
Rated 5 out of 5 by from nice speakerUsing as a center channel, works great for voice in movies and audio tracks, need better speaker wire connection or 1/4 in jack but its ok, i like it
Date published: 2014-09-16
Rated 4 out of 5 by from Had to try them, and I like themI was looking for single driver speakers for my TV system main left and right speakers. I don't like using multi-way speakers for regular TV viewing because they tend to muddy up the dialog and have too much bass. I have some very large DIY tri-amped speakers for watching concert videos or movies, so I was looking for something for regular TV only. I compared them on my studio desk to an old Radio Shack Lineaum 5" 2-way speaker and these don't have as much low-end or high-end, but that did not concern me. Where these excel is midrange clarity and blending in with the rest of my 6.1 surround system. The quality of the cabinet and driver appears to be very good. The mounting options worked out great for my situation. I didn't like the input screw terminals so the first thing I did was remove the terminal cup and modify it for a Speakon chassis mount connector. I installed the 2-pole part number 092-059 because I had a pair on hand, but I would recommend the 4-pole part number 092-067 only because I have a lot of 4-pole connectors and cables. I forgot the 4-pole male won't fit the 2-pole chassis mount. I would only recommended this modification if you are confident with a Dremel tool.
Date published: 2013-10-03
  • 2015-08-31T07:10CST
  • co_hasreviews, tv_0, tr_6
  • loc_en_US, sid_299-460, PRD, sort_mostRecent
Will these speakers work as studio monitors?
Asked by: dani537
These would work well as stand mount stage monitors, but I would not recommend them for high resolution studio playback.
Date published: 2015-07-31
are there grills to buy for these speakers and if so how much for the grills
Asked by: wedo
Unfortunately grills are not available for these speakers.
Date published: 2015-07-14
Can you recommend a Amplifier Board to fit in this unit? I want to use it as a Powered Driver for my Kala U-Bass..
Asked by: tourboy
Date published: 2015-03-17
How much room do you have between the top or the bottom of the 6.5'' driver to mount a tweeter?
Asked by: Calera05
The distance between the driver frame and the inside edge of the cabinet is 2-1/4".
Date published: 2015-02-27
I have a low watt vintage tube amp that "overproduces" in the high frequency range but otherwise sounds good. I currently only own two and three way cabs and the highs are just too harsh. Do you think a single driver system could help solve this problem?
Asked by: eyevibe21
This requires a bit more information in order to proceed. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2014-12-31
For those of us in the "Hi-Fi" single driver camp, would these make a pair for that use, as long as a sub fills in the low end?
Asked by: David B
They can certainly be used for that application, yes.
Date published: 2014-09-22
  • 2015-08-31T07:32CST
  • co_hasquestionsanswers, tq_11
  • loc_en_US, sid_299-460, PRD, sort_recentQuestionsFirst
