Peavey RD 1.6 Versarray Ribbon Tweeter 7 Ohm
Brand:|Model: RD 1.6|Part # 299-465
Repair your Peavey Versarray speakers, or build a set of high output speakers with Peavey's RD 1.6 ribbon tweeter. The high, 97 dB (@2.83V) sensitivity keeps up with many professional audio drivers. A stackable design also makes this a great choice for line arrays. Parts Express exclusive buyout!
Part # 299-465
  • Peavey Versarray ribbon tweeter
  • 8 mm wide by 120 mm high reinforced ribbon diaphragm
  • High output for a true ribbon tweeter, 97 dB
  • Extremely fast transient response, wide frequency response, and high sensitivity
Peavey used the RD 1.6 ribbon tweeter in their acclaimed Versarray™ series of line array speakers to set a new benchmark for high fidelity, in sound reinforcement applications, while retaining high sensitivity and wide dispersion.
A 4.72" high by 0.31" wide sandwiched-aluminum diaphragm is immersed in magnetic flux from the neodymium magnet, and a built-in, step-up transformer keeps the impedance at a benign 7 ohm load for simple crossover calculation while maximizing output for a high 97 dB sensitivity at 2.83V.
The natural planar wavefront of the RD 1.6 minimizes vertical off-axis dispersion, making this tweeter conducive to a stacked line array design with minimal comb filtering effects. Horizontal off-axis dispersion remains nearly flat to 45° from the high-pass crossover point (2,500 Hz @ 18 dB/octave is recommended) out to 40,000 Hz. This increases the sweet spot, for life-like imaging across a wider sound stage.
Save on the Peavey RD 1.6 planar ribbon tweeter through this Parts Express exclusive buyout. Quantities are limited.
  • Tweeter TypeRibbon
  • Impedance7 ohms
  • Power Handling (RMS)20 Watts
  • Frequency Response1,200 to 40,000 Hz
  • Sensitivity97.0 dB 1W/1m
  • DC Resistance (Re)0.02 ohms
  • Overall Outside Diameter6.50 x 3.35"
  • Cutout Diameter4.88 x 2.40"
  • Depth2.90"
  • BrandPeavey
  • ModelRD 1.6
  • Part Number299-465
  • UPC848864007816
  • Product CategoryTweeters
    (9 Reviews)
  • Weight2.2000 lbs.
View similar products to the Peavey RD 1.6 Versarray Ribbon Tweeter 7 Ohm
in the Tweeters product category.
