BONUS ITEM INCLUDED
248-8356_ALT_0
Peavey PVi 8B 8-Channel Powered Mixer 150W
Brand:|Model: PVi 8B|Part # 248-8356
The PVi 8B powered mixer is easy to use and transport, and is designed with the latest Peavey technology. Constructed with a rugged metal structure, wood cabinet, vinyl surface and protective corners, the PVi 8B is the ideal powered mixer.
List Price$399.99
You Save30%
$279.99
Peavey Baseball Cap
Qty: 1Part # 520-302
List Price:$19.99
Part # 248-8356
  • 150 watts into 4 ohm (2 x 8 ohm) speakers
  • 8 balanced XLR microphone inputs
  • Tape/CD inputs
  • Reverb level control on each channel
  • Line Out for connection to external amplifiers
  • Return input for connection of external effects processors
  • Record Out for taping
PVi Powered Mixers are easy to use and transport, and are designed with exclusive Peavey techonology! The PVi 8B powered mixer is easy to use and transport, and is designed with the latest Peavey technology. Constructed with a rugged metal structure, wood cabinet, vinyl surface and protective corners, the PVi 8B is the ideal powered mixer. Peavey item 00595560.
Specifications: • Output power: 150 watts 4 ohms; 100 watts 8 ohms • Aux SEND output: -10 dBv nominal, 1k ohms • Tape REC output: -10 dBv nominal, 1k ohms • Input impedance: Low-Z mic 1k ohms; High-Z line 10k ohms • Protection circuit: Power on Mute delay time 2 seconds • Power consumption: 200 watts • Dimensions: 8" H x 20.36" W x 12.13" D (20.3 x 51.8 x 30.8 cm).
PRODUCT SPECIFICATIONS
  • Mixer TypeAnalog
  • XLR Mic Inputs6 to 8
  • BrandPeavey
  • ModelPVi 8B
  • Part Number248-8356
  • UPC014367128505
  • Product CategoryPowered Mixers
    (1 Reviews)
  • Weight25 lbs.
View similar products to the Peavey PVi 8B 8-Channel Powered Mixer 150W
in the Powered Mixers product category.
Peavey PVi 8B 8-Channel Powered Mixer 150W is rated 3.0 out of 5 by 1.
Rated 3 out of 5 by from Good Puchass for the for the cost of priceShipping was good no problem it arrived right on time.Peavey PVi 8B 8-Channel Powered Mixer 150Wis a good mixer for indoors for practise or rehearsels. Compared to the peavey 100W back in the day this amp sounds like a 25 watt amp.
Date published: 2013-02-14
  • 2016-02-14T06:53CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_248-8356, PRD, sort_mostRecent
