Peavey PV 215EQ Dual 15-Band Graphic Equalizer
Brand:|Model: PV 215EQ|Part # 248-8118
The PV® 215EQ dual 15-band 2/3 octave graphic EQ is a single rack space unit that's a simple and affordable solution to equalization.
Part # 248-8118
  • 1 RU dual 15-band stereo
  • Switchable 12-band or 6 dB boost/cut range
  • 80 Hz 24 dB low cut filter
  • XLR balanced I/O
  • Output level LEDs
  • Bypass switch with status LED
  • 20 mm center-detent control sliders
The PV® 215EQ dual 15-band 2/3 octave graphic EQ is a single rack space unit that's a simple and affordable solution to equalization. Select between 6 dB or 12dB cut or boost over frequencies ranging from 25 Hz to 16 kHz. Low cut filter switch with status LED helps remove rumble from open mics. Peavey item 00573680.
Specifications: Dimensions: 19" W x 1.75" H x 8.75" D.
  • BrandPeavey
  • ModelPV 215EQ
  • Part Number248-8118
  • UPC0014367114058
  • Product CategoryEqualizers
    (1 Reviews)
  • Weight9 lbs.
View similar products to the Peavey PV 215EQ Dual 15-Band Graphic Equalizer
in the Equalizers product category.
