Bonus Item Incl.
Peavey PV 14 10 Mic/4 Line Input Stereo Mixer
Brand:| Model: PV 14
The new PV Series mixers bring you the features and value that you have come to expect from Peavey. Small size and price, big performance!
  • 10 RQ™ Reference Quality low noise XLR mic inputs
  • Built-in DSP effects with 16 settings and variable parameter control
  • Channel inserts on 1-10
  • Channel mute switch with LED indicator
  • 2 independent stereo line inputs with balanced/unbalanced 1/4" jacks and dual RCAs
  • Channel clip LEDs, dual eight-segment output LEDs
  • Signal present LEDs on input channels
248-815
Weight: 19.7 lbs.
IN STOCK
Order Soon - Only 1 Left In Stock
List Price$429.99
You Save30%
$299.99
Peavey Baseball Cap
Qty: 1Part # 520-302
List Price:$19.99
Part # 248-815
The PV® Series has long been the benchmark of performance and value in audio, and Peavey's new PV mixers live up to this legacy. With the same reference-quality microphone preamps used in Peavey RQ™ Series mixers and an astonishingly low THD (Total Harmonic Distortion) of 0.0007%, these new mixers are equally useful in project studios or live/program music mixing situations. The new PV Series mixers bring you the features and value that you have come to expect from Peavey. Small size and price, big performance! The PV14 features 10 mic/line inputs, 2 stereo line inputs, one pre fader post EQ aux send, 1 post fader aux send, and a durable steel chassis. Peavey item 00512140.
PRODUCT SPECIFICATIONS
  • Mixer TypeAnalog
  • Special FeaturesBuilt-In Digital Effects
  • XLR Mic Inputs10 to 14
  • BrandPeavey
  • ModelPV 14
  • Part Number248-815
  • UPC014367112887
  • Product CategoryMixers - Live Sound & Recording
  • Weight19.7 lbs.
View similar products to the Peavey PV 14 10 Mic/4 Line Input Stereo Mixer
in the Mixers - Live Sound & Recording product category.
Why the clearance requirements on the Peavey PV-14 mixer?
Why are the following clearance specs so important for the Peavey PV-14 mixer:This unit must have the following clearances from any combustible surface:top: 8", sides: 12", back: 12"? I have not noticed any noticeable heat from this mixer.
Asked by: jlstahlecker
Manufactures list clearance requirements for anything that has the potential of getting warm or hot for liability reasons. I cannot specifically say it is safe to have the unit enclosed inside anything smaller than the stated dimensions although you can contact Peavey and as them directly. You can find their contact information at www.peavey.com.
Date published: 2012-10-12
What sort of outputs does this mixer have?
How many outputs and aux sends does this mixer have and are they XLR or 1/4 inch outputs - balanced or unbalanced?
Asked by: Chayla
This Peavey mixer has all of the industry standard outputs you would find on most mid level sound reinforcement units.It has both XLR and 1/4in outputs for the main mix. You can use these at the same time however, they are most likely wired in parallel versus isolated so if you do use both inputs at once it will cause the XLR to become unbalanced.The mixer does NOT have an alternate mix bus such as the Yamaha Mg166cx. This is a helpful feature for simultaneous recording/live sound.Other outputs include a headphone jack with independent volume control, stereo control room out (1/4in), stereo recording out (RCA connectors), and mono effects send and mono monitor send.Please be aware that this unit does not have an aux return or effects return meaning it will be difficult to use with an external processing unit.The record out (RCA connectors) on most mixers is independent of the main mix fader, meaning that the volume is the same as the channel inputs regardless of the main mix level.In my opinion this mixer is better suited for garage bands than an audio engineer. It's hard to find a mixer much more simple than this one. For beginners its good but one will quickly outgrow its capabilities.I can not speak for quality.
Answered by: VictorE
Date published: 2012-01-04
  • 2015-03-28T07:28CST
  • loc_en_US, sid_248-815, PRD, sort_recentQuestionsFirst
Customer projects that include: Peavey PV 14 10 Mic/4 Line Input Stereo Mixer
