Peavey Pro 12 Low Frequency 12" Speaker Driver
Brand:|Model: Pro 12|Part # 294-3124
Peavey's Pro Audio replacement speakers are great for getting your Professional cabinet and DJ speakers up and running again, at an economical price.
List Price$71.99
You Save20%
$57.59
Part # 294-3124
Peavey's Pro Audio replacement speakers are great for getting your Professional cabinet and DJ speakers up and running again, at an economical price. Kevlar® reinforced paper cones, Kapton formers with Nomex® stiffeners, and stamped steel frames increase durability without affecting sensitivity (for high output),  or power handling. Peavey Pro Audio replacement drivers work well in ported or sealed cabinets. Peavey item 00497070.
  • Nominal Diameter12"
  • Power Handling (RMS)200 Watts
  • Power Handling (max)800 Watts
  • Impedance8 ohms
  • Frequency Response50 to 4,000 Hz
  • Sensitivity94.3 dB 1W/1m
  • Voice Coil Diameter2.375"
  • Resonant Frequency (Fs)48.4 Hz
  • DC Resistance (Re)6 ohms
  • Voice Coil Inductance (Le)0.72 mH
  • Mechanical Q (Qms)3.84
  • Electromagnetic Q (Qes)0.59
  • Total Q (Qts)0.51
  • Compliance Equivalent Volume (Vas)3.05 ft.³
  • Mechanical Compliance of Suspension (Cms)0.22 mm/N
  • BL Product (BL)12.36 Tm
  • Diaphragm Mass Inc. Airload (Mms)49.1g
  • Maximum Linear Excursion (Xmax)2.5 mm
  • Surface Area of Cone (Sd)530 cm²
  • Cone MaterialPaper / Kevlar
  • Magnet MaterialFerrite
  • Overall Outside Diameter12"
  • Baffle Cutout Diameter11"
  • Depth5.75"
  • # Mounting Holes8
  • Sealed Volume2.01 ft.³
  • Sealed F375 Hz
  • Vented Volume5.12 ft.³
  • Vented F337 Hz
  • BrandPeavey
  • ModelPro 12
  • Part Number294-3124
  • UPC014367106411
    (12 Reviews)
  • Weight12.25 lbs.
View similar products to the Peavey Pro 12 Low Frequency 12" Speaker Driver
Peavey Pro 12 Low Frequency 12" Speaker Driver is rated 4.9167 out of 5 by 12.
Rated 5 out of 5 by from Great ValueUsed this to replace a smoked stage monitor. This one is tight and punchy. Sounds better than the original that it replaced and it's twin that still has the oem driver. Took a lesser name brand product and made it into something great!
Date published: 2015-04-23
Rated 4 out of 5 by from No regrets for my applicationI got some cheap tower KLH speakers the twelves were making some noise so I bought these to replace them they work wonderfully
Date published: 2014-11-14
Rated 5 out of 5 by from Good product!!Bought this a month ago and im glad i did. Very fast shipping too!!
Date published: 2014-11-04
Rated 5 out of 5 by from Very helpful tech staffWith the guidance of the tech staff, this speaker has worked perfectly for my bass guitar amp.
Date published: 2013-10-02
Rated 5 out of 5 by from Clear As A BellI'd bought a pair of these and teamed them up with three BOFUs and a piezo tweeter. The results were so good that when I needed to build two PA towers, I bought a second pair. The towers have two of these, four BOFUs and a titanium horn. I've had them up to their full 600 W/RMS capacity and they handle it with ease. The clean and crisp bass has a punch you can feel in your gut. There is no need for subs. I'll be buying another pair to replace the drivers in a 30 year old 2x12 bass combo amp. These are truly premium speakers.
Date published: 2013-06-13
Rated 5 out of 5 by from Peavey Pro 12 (and Pro 10) SpeakersI updated some 30 year old Peavey 1210 cabinet speakers, each with a 12" and 10" speaker, with Peavey Pro 12" and 10" speakers from PartsExpress. My band uses these cabinets for mids and highs and run them with QSC amps (which sound great with them) and some nice subwoofers to cover the lows. For less than the price of a single decent Yamaha or Peavey PA speaker cabinet, I was able to upgrade all the old speakers with these - and they really sound fantastic. We run everything through our PA, including an entire mic'd drum kit and these speakers handle everything over 200Hz (below that is handled by our subwoofers) with a great punchy sound - you can even "feel" the lower frequencies better with these speakers.I'm giving these speakers 5 stars for what they are. There are clearly more high-end speakers out there, but for the power handling capability, clarity and price, they are capable of doing a fantastic job in small and medium sized venues based on speaker setup.
Date published: 2013-05-31
  • 2016-02-10T06:48CST
  • co_hasreviews, tv_0, tr_12
  • loc_en_US, sid_294-3124, PRD, sort_mostRecent
Hi. I haves two peavey low max subs,and two peavey black widow tops with rx14 tweeters. I am running them through the peavey crossovers as recommended by peavey tech. Can you recommend a good strong reliable amp about 2000w rms per channel? john.uk.x
Asked by: Johnnyboy 2112
IPR7500
Answered by: Peavey Help
Date published: 2015-07-20
Thinking of using a pair of these as replacements in Behringer F122A will they work?
Asked by: JackievsBrittney2wiceaday
Yes these will work fine for that application.
Date published: 2014-08-19
Is this suitable as a replacement in a Peavey TLS 2X cabinet? Which high frequency driver would make a suitable replacement as well?
Asked by: albey2k
This will work well as a replacement woofer in that cabinet. It uses a an 14XT driver stock so this would be ideal as a replacement.http://www.parts-express.com/peavey-14xt-compression-driver--294-3134
Date published: 2014-07-08
I am considering 4 of these speakers for two old peavey 2 x 12 sealed pa cabinets, for use as a bass guitar rig. Has anyone used these for bass?
Asked by: cementhead
These will be power limited in a sealed cabinet with their excursion capabilities. The woofer will have to be determined by the box volume, porting may be the best option.
Date published: 2013-04-15
Is this a suitable replacement speaker for the Peavey Bandit 112, with the 12" Sheffield speaker, model 1230?
Asked by: Dan R
In my opinion, no, this is not an obvious good choice for a guitar amp speaker replacement.This is a low frequency speaker designed to be used with a tweeter in a high power, low distortion application, such as a small mains or monitor speaker. The Sheffield speaker, and the Blue Marvel speaker, which PV also uses in the Bandit amps, are designed as guitar speakers. They tend to be louder, lighter in construction, and more prone to distortion than this speaker. Even in a modeling amp, there is an expectation of some cone break-up as part of the guitar speaker sound. You won't get that with a Kevlar cone, which is much stiffer and less prone to break-up than a guitar speaker.That being said, there are a few people who really love the sound of a stiff low break-up speaker in a guitar amp. The really heavy EV speakers are an example. Guitar speakers are a matter of taste more than specs, but the odds of most guitar players loving this choice is small.
Answered by: Bushman
Date published: 2014-05-25
  • 2016-02-10T07:35CST
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_294-3124, PRD, sort_recentQuestionsFirst
