294-3126_ALT_0
294-3126_ALT_1
Peavey Pro 10 Low Frequency 10" Speaker Driver
Brand:|Model: Pro 10|Part # 294-3126
Peavey's line of Pro Audio replacement speakers are great for getting your professional cabinet and DJ speakers up and running again, at an economical price.
List Price$59.99
You Save20%
$47.99
Part # 294-3126
Peavey's Pro Audio replacement speakers are great for getting your professional cabinet and DJ speakers up and running again, at an economical price. Kevlar® reinforced paper cones, Kapton formers with Nomex® stiffeners, and stamped steel frames increase durability without affecting sensitivity (for high output),  or power handling. Peavey Pro Audio replacement drivers work well in ported or sealed cabinets. Peavey item 00497060.
  • Nominal Diameter10"
  • Power Handling (RMS)200 Watts
  • Power Handling (max)800 Watts
  • Impedance8 ohms
  • Frequency Response50 to 4,000 Hz
  • Sensitivity94.3 dB 1W/1m
  • Voice Coil Diameter2.5"
  • Resonant Frequency (Fs)67.7 Hz
  • DC Resistance (Re)6 ohms
  • Voice Coil Inductance (Le)0.72 mH
  • Mechanical Q (Qms)2.85
  • Electromagnetic Q (Qes)0.46
  • Total Q (Qts)0.4
  • Compliance Equivalent Volume (Vas)0.89 ft.³
  • Mechanical Compliance of Suspension (Cms)0.15 mm/N
  • BL Product (BL)14.33 Tm
  • Diaphragm Mass Inc. Airload (Mms)36.9g
  • Maximum Linear Excursion (Xmax)2.5 mm
  • Surface Area of Cone (Sd)350 cm²
  • Cone MaterialPaper / Kevlar
  • Magnet MaterialFerrite
  • Overall Outside Diameter10.125"
  • Baffle Cutout Diameter9"
  • Depth4.875"
  • # Mounting Holes8
  • Sealed Volume0.28 ft.³
  • Sealed F3136 Hz
  • Vented Volume0.68 ft.³
  • Vented F374 Hz
  • BrandPeavey
  • ModelPro 10
  • Part Number294-3126
  • UPC014367106404
    (10 Reviews)
  • Weight11.3 lbs.
