Peavey PR 15D 15" Powered Bi-Amplified 2-Way Active PA Speaker System
Brand:|Model: PR 15D|Part # 248-856
The PR® 15D features a bi-amped power section that provides 150 watts power for the woofer and 50 watts power for the compression driver tweeter, both with Peavey-exclusive DDT™ compression.
Part # 248-856
  • Extremely powerful, lightweight, and versatile
  • Bi-amplified Class-D powered system with 200 watts total power and DDT compression
  • Heavy-duty 15" woofer and an RX14™ 1.4" titanium compression driver
  • Durable injection-molded polypropylene enclosure with integral fittings
  • Woofer servo circuit reduces distortion
  • Peak SPL up to 120 dB with music!
The Peavey PR 15D is a powered, bi-amplified, two-way speaker system engineered to provide very high levels of performance in a compact powered loudspeaker. The PR 15D is capable of up to 120 dB peak SPL. The enclosure utilizes tough polypropylene in an injection-molded plastic trapezoidal form, with a coated steel grille to offer an attractive yet-durable powered speaker system.
This two-way powered system is comprised of a 150W class D power amplifier driving a 15" heavy duty woofer. The RX™14 compression driver is driven by a 50W class D power amplifier and features a 1.4" titanium diaphragm coupled to an extremely smooth and well-controlled constant directivity horn (with a coverage pattern of 90? by 40?) that is molded integrally into the enclosure.
A balanced input to the preamp/EQ electronics consists of one combo female XLR and 1/4" TRS phone jack. It is switchable between mic-level and line-level sensitivity. Two 1/4” phone jacks are provided for link-out / direct-in capability. The link-out is post- level and pre-crossover. While the direct-in is a direct pre-crossover input.
A woofer servo senses back-EMF from the woofer voice coil that is not a result of the drive signal, and subtracts the error so that the woofer cone follows the drive waveform precisely.
Constant Loudness (Fletcher-Munson) circuit for accentuating bass and treble at low listening volume levels.
The power amplifiers providing the bi-amplification are low-distortion units providing 150W continuous RMS into the nominal 8 ohm load of the woofer, and a 50W continuous RMS into the nominal 8 ohm load of the tweeter. They were selected for their reliability and superb musical performance capability. Both amplifiers feature DDT™ compression, which virtually eliminates audible power amplifier clipping.
A molded-in handle provides ease of transport, while multiple mounting points (top and bottom) for the Peavey Versamount™ allow maximum utility.
The Peavey PR®15D has a variety of applications such as sound reinforcement, public address, side fill system, karaoke or musical playback. With the optional monitor stand kit, the Peavey PR 15D makes an excellent stage monitor. Peavey item 03586620.
Specifications: • Internal power amplifiers (@ 120 VAC line): Woofer: 150 Watts @ less than 0.1% distortion; Tweeter: 70 Watts peak dynamic power, 50 Watts @ less than 0.1% distortion • Crossover frequency: 2,000 Hz • Crossover type: Internal electronic 18 dB/octave two-way crossover with CD horn EQ, level matching, bass boost and subsonic filtering • Frequency response: 47 Hz to 20 kHz • Sensitivity: 97 dB at 1W/1m • Nominal coverage pattern: 90° x 40° • Power requirements: Nominal 110 Watts, 120 VAC, 60 Hz • Net weight: 40.9 lbs. • Dimensions: 28.6" H x 21.3" W x 17" D.
  • Speaker TypeActive / Powered
  • Woofer Size15"
  • BrandPeavey
  • ModelPR 15D
  • Part Number248-856
  • UPC014367142709
  • Weight47.55 lbs.
View similar products to the Peavey PR 15D 15" Powered Bi-Amplified 2-Way Active PA Speaker System
