Peavey IPR2 7500 Power Amplifier
Brand:|Model: IPR2 7500|Part # 248-7986
The groundbreaking Peavey IPR2 7500 power amplifier utilizes an advanced design to dramatically reduce weight while increasing output power, reliability and thermal efficiency.
List Price$1,799.99
You Save39%
$1,099.99
Peavey Baseball Cap
Qty: 1Part # 520-302
List Price:$19.99
*Domestic US orders only
Part # 248-7986
  • Cool-running, high headroom, lightweight amp for subs or full-range speakers
  • Independent Linkwitz-Riley crossovers on each channel
  • DDT protection helps prevent distortion, speaker overload, and damage
  • Revolutionary IPR Class D topology for reduced weight and unrivaled efficiency
  • XLR and 1/4" inputs; combo twist-lock speaker output connectors
  • Detented input controls
Peavey's IPR2 7500 power amp boasts over 3,700 watts per channel at 2 ohms and weighs less than 15 lbs. It also features two channel-independent Linkwitz-Riley crossovers, a variable-speed fan housed in a lightweight aluminum chassis, patented DDT speaker protection, and the revolutionary IPR Class D topology.
IPR2 Series amplifiers are designed with a resonant switch-mode power supply and a high-speed Class D topology that yields the highest audio resolution and efficiency available. This revolutionary amplifier offers the sonic superiority and unsurpassed reliability for which Peavey is famous, in an extremely efficient and lightweight design.
Advanced technology and extensive protection circuitry facilitate operation with greater efficiency into difficult loads and power conditions. The DDT™ (Distortion Detection Technique) circuitry enables trouble-free operation into loads as low as 2 ohms. DDT protects drivers and ensures that sonic integrity is maintained, even in extreme overload conditions. The IPR2's high-efficiency design allows the amplifier to operate at very low temperatures, and does not require massive heat sinks for cooling. Peavey item 03004250.
Specifications: • Power output (EIA 1 kHz, both channels driven): 1,200 watts x 2 (8 ohms), 2,020 watts x 2 (4 ohms) 3,750 watts x 2 (2 ohms) • Distortion (typical): <0.15% @ 8 and 4 ohms, <1% @ 2 ohms • Hum and noise > -106 dB, "A" weighted referenced to rated power @ 4 ohms • Frequency response: 20 Hz - 35 kHz (+0.0 dB, -3.0 dB at 1 watt) • Voltage gain at 8 ohms: 40x (+32 dB) • Crosstalk: > -85 dB @ 1 kHz, 1,000 watts power @ 8 ohms • Input sensitivity: 2.25V for 1 kHz, 4 ohm rated power, 2.195V for 1 kHz 2 ohm rated power • Input impedance: 20k ohms balanced, 10k ohms unbalanced • Crossover: 100 Hz switchable 2nd order high pass and 3rd order low pass per channel • Minimum load impedance: 2 ohms • Damping factor (8 ohms, 20 Hz - 1 kHz): >200 • Dimensions: 3.5" (2RU) H x 19" W x 17" D behind front panel (+ 0.6" for handle) • Weight: 14.6 lbs.
  • Power Output (RMS Per Channel @ 8 ohms)1250 Watts
  • Output Channels2
  • Weight Range10 to 19 lbs.
  • BrandPeavey
  • ModelIPR2 7500
  • Part Number248-7986
  • UPC014367153439
  • Weight20.6000 lbs.
View similar products to the Peavey IPR2 7500 Power Amplifier
Part # 248-7986
