Peavey IPR2 5000 DSP Power Amplifier
Brand:|Model: IPR2 5000 DSP|Part # 248-7989
The groundbreaking IPR2 series utilizes an advanced design that allows Peavey engineers to dramatically reduce weight while increasing output power, reliability and thermal efficiency. The DSP models in this series feature independent, assignable crossover points, delay, EQ presets, security lock settings and an intuitive setup wizard.
List Price$1,599.99
You Save38%
$999.99
Peavey Baseball Cap
Qty: 1Part # 520-302
List Price:$19.99
*Domestic US orders only
Part # 248-7989
  • Independent, assignable crossover points, delay, and EQ presets
  • DDT protection
  • Revolutionary IPR class D topology
  • Detented input controls
  • Combination XLR and 1/4" inputs
  • Twist-lock output connectors
  • Light weight
The IPR2 5000 DSP boasts over 2,500 watts per channel at 2 ohms and weighs less than 15 lbs. It also features 2-channel independent Linkwitz-Riley crossovers, a variable-speed fan housed in a lightweight aluminum chassis, patented DDT speaker protection, and the revolutionary IPR class D topology.
IPR2 Series amplifiers are designed with a resonant switch-mode power supply and a high-speed class D topology that yields the highest audio resolution and efficiency available. This revolutionary amplifier offers the sonic superiority and unsurpassed reliability for which Peavey is famous, in an extremely efficient and lightweight design.
Advanced technology and extensive protection circuitry allow operation with greater efficiency into difficult loads and power conditions. The DDT™ (Distortion Detection Technique) circuitry ensures trouble-free operation into loads as low as 2 ohms. DDT protects drivers and ensures that sonic integrity is maintained, even in extreme overload conditions. The IPR2's high-efficiency design allows the amplifier to operate at very low temperatures, and does not require massive heat sinks to cool. Peavey item 03004470.
Specifications: • Power output (EIA 1 kHz, both channels driven): 880 watts x 2 (8 ohms), 1,470 watts x 2 (4 ohms) 2,530 watts x 2 (2 ohms) • Distortion (typical): <0.15% @ 8 and 4 ohms, <1% @ 2 ohms • Hum and noise > -96dB, "A" weighted referenced to rated power @ 4 ohms • Frequency response: 20 Hz - 22 kHz (±0.05 dB @ 4 ohms) • Voltage gain at 8 ohms: 70x (+37 dB) • Crosstalk: > -60 dB @ 1 kHz, 700 watts power @ 8 ohms • Input sensitivity: 1.094V for 1 kHz, 4 ohm rated power, 1.025V for 1 kHz 2 ohm rated power • Input impedance: 12k ohms balanced, 6k ohms unbalanced • Crossover: Adjustable high pass and low pass filter per channel. Filter types: 12dB/octave 2nd order, 18dB/octave 3rd order, 24dB/octave 4th order Butterworth, and 24dB/octave 4th order Linkwitz-Riley • Minimum load impedance: 2 ohms • Damping factor (8 ohms, 20 Hz - 1 kHz): >210 • Dimensions: 3.5" (2RU) H x 19" W x 17" D behind front panel (+ 0.6" for handle) • Weight: 13.6 lbs.
  • BrandPeavey
  • ModelIPR2 5000 DSP
  • Part Number248-7989
  • UPC014367153460
  • Weight20.3500 lbs.
View similar products to the Peavey IPR2 5000 DSP Power Amplifier
Part # 248-7989
