Peavey IPR 3000 DSP Power Amplifier
Brand:|Model: IPR 3000 DSP|Part # 248-7992
The Peavey IPR™ 3000 professional power amplifier with DSP boasts 1,450 watts per channel at 2 ohms and weighs in at a mere 7.5 lbs. Features adjustable fourth order Linkwitz-Riley crossovers, DDT circuitry, and much more!
  • DSP-based Loudspeaker Management System
  • DDT™ protection
  • Revolutionary IPR class D topology
  • Detented input controls
  • Combination XLR 1/4" inputs
  • Combination 1/4" or 1/4" 4 pole twist lock output connector
  • Lightweight
Frequently Bought Together
The groundbreaking IPR series utilizes an advanced design that allows Peavey engineers to dramatically reduce weight while increasing output power, reliability and thermal efficiency. IPR Series amplifiers are designed with a resonant switch-mode power supply and a high-speed class D topology that yields the highest audio resolution and efficiency available. With the IPR DSP 3000 you get the DSP based Loudspeaker Management System. The DSP was designed to be incredibly effective, yet extremely easy to use. Using unique and revolutionary advanced bass enhancement processes, the IPR DSP amplifiers dramatically improve the perceived level of bass in any system, using a fraction of the power that would be required with any other power amp.
The PV IPR DSP 3000 boasts 1450 watts RMS per channel at 2 ohms and is under 8 lbs. The IPR DSP features independent, assignable crossover points, delay, EQ presets, security lock settings and a intuitive setup wizard. Combined with a variable-speed fan housed in a lightweight aluminum chassis, DDT speaker protection, and the revolutionary new IPR class D topology.
The DDT™ (Distortion Detection Technique) circuitry ensures trouble-free operation into loads as low as 2 ohms. DDT protects drivers and ensures that sonic integrity is maintained, even in extreme overload conditions. The IPR's high-efficiency design allows the amplifier to operate at very low temperatures, and does not require massive heat sinks to cool.
Specifications: • Power output (@ 1 kHz at <0.1% THD both channels driven): 430 watts RMS x 2 (8 ohms), 815 watts RMS x 2 (4 ohms), 1,450 watts RMS x 2 (2 ohms) • Power output (@ 1 kHz at <0.1% THD single channel driven): 450 watts RMS x 1 (8 ohms), 910 watts RMS x 1 (4 ohms), 1,590 watts RMS x 1 (2 ohms) • Frequency response: 10 Hz - 22 kHz (±0.5 dB at 1 watt) • Crossover: Adjustable frequencies with 24 dB/oct., 4th order Linkwitz-Riley High Pass and Low Pass filter per channel • Input sensitivity: 1.215 volts ±3% for 1 kHz 4 ohm rated power; 1.195 volts ±3% for 1 kHz. 2 ohm rated power • Hum and Noise: ≥92 dB, "A" weighted referenced to rated power @ 4 ohms • Damping factor (8 ohms): >225:1 @ 20 Hz - 1 kHz (at 8 ohms) • Minimum load impedance: 2 ohms • Maximum RMS voltage swing: 67 volts • Voltage gain: x 47 (+33.4 dB) • Cooling: Temperature dependent variable speed 80 mm DC fan • Net weight: 7.50 lbs. • Dimensions: 3.5" H x 19" W x 10.5" D (behind front panel, + 0.6" for handle).
  • Power Output (RMS Per Channel @ 8 ohms)430 Watts
  • Weight Range< 10 lbs.
  • BrandPeavey
  • ModelIPR 3000 DSP
  • Part Number248-7992
  • UPC014367153453
  • Weight10.6 lbs.
View similar products to the Peavey IPR 3000 DSP Power Amplifier
Part # 248-7992
