Peavey IPR 1600 DSP Power Amplifier
Brand:|Model: IPR 1600 DSP|Part # 248-7990
The Peavey IPR™ 1600 professional power amplifier with DSP boasts 900 watts per channel at 2 ohms and weighs in at a mere 7 lbs. Features 2 channel independent fourth order Linkwitz-Riley crossovers, a variable-speed fan housed in a lightweight aluminum chassis, and much more!
Comparable Items In Stock:
Part # 248-7990
  • DSP-based Loudspeaker Management System
  • DDT™ protection
  • Revolutionary IPR class D topology
  • Detented input controls
  • Combination XLR 1/4" inputs
  • Combination 1/4" or 1/4" 4 pole twist lock output connector
  • Lightweight
The groundbreaking IPR series utilizes an advanced design that allows Peavey engineers to dramatically reduce weight while increasing output power, reliability and thermal efficiency. IPR Series amplifiers are designed with a resonant switch-mode power supply and a high-speed class D topology that yields the highest audio resolution and efficiency available. With the IPR DSP 1600 you get the DSP based Loudspeaker Management System. The DSP was designed to be incredibly effective, yet extremely easy to use. Using unique and revolutionary advanced bass enhancement processes, the IPR DSP amplifiers dramatically improve the perceived level of bass in any system, using a fraction of the power that would be required with any other power amp.
The DDT™ (Distortion Detection Technique) circuitry ensures trouble-free operation into loads as low as 2 ohms. DDT protects drivers and ensures that sonic integrity is maintained, even in extreme overload conditions. The IPR's high-efficiency design allows the amplifier to operate at very low temperatures, and does not require massive heat sinks to cool. Peavey item 03004390.
Specifications: • Power output (@ 1 kHz at <0.1% THD both channels driven): 290 watts RMS x 2 (8 ohms), 515 watts RMS x 2 (4 ohms), 900 watts RMS x 2 (2 ohms) • Power output (@ 1 kHz at <0.1% THD single channel driven): 300 watts RMS x 1 (8 ohms), 570 watts RMS x 1 (4 ohms), 1,050 watts RMS x 1 (2 ohms) • Frequency response: 10 Hz - 22 kHz (±0.5 dB at 1 watt) • Crossover: Adjustable frequencies with 24 dB/oct., 4th order Linkwitz-Riley High Pass and Low Pass filter per channel • Input sensitivity: 1.14 volts ±3% for 1 kHz 4 ohm rated power; 1.07 volts ±3% for 1 kHz. 2 ohm rated power • Hum and Noise: ≥92 dB, "A" weighted referenced to rated power @ 4 ohms • Damping factor (8 ohms): >150:1 @ 20 Hz - 1 kHz (at 8 ohms) • Minimum load impedance: 2 ohms • Maximum RMS voltage swing: 55 volts • Voltage gain: x 40 (+32 dB) • Cooling: Temperature dependent variable speed 80 mm DC fan • Net weight: 7.12 lbs. • Dimensions: 3.5" H x 19" W x 10.5" D (behind front panel, + 0.6" for handle).
  • Power Output (RMS Per Channel @ 8 ohms)290 Watts
  • Output Channels2
  • Weight Range< 10 lbs.
  • BrandPeavey
  • ModelIPR 1600 DSP
  • Part Number248-7990
  • UPC014367153446
  • Weight9.66 lbs.
View similar products to the Peavey IPR 1600 DSP Power Amplifier
Part # 248-7990
