Bonus Item Incl.
294-326_ALT_0
Peavey ECS-3X PA Cabinet Speaker Crossover 500/2500 Hz 3-Way
Brand:| Model: ECS-3X
These cabinet-ready passive 3-way crossover networks are pre-engineered to provide all the frequency division and driver protection that you could need for your speaker system.
  • Ready to mount in your enclosure
  • Use with 6" to 10" cone midrange, 12" or 15" woofer
  • CD horn compensation
  • SoundGuard™ overload protection on mid and high frequency drivers
  • 500 Hz and 2500 Hz 12 dB/octave crossover frequencies
  • 1/4" and Neutrik Speakon® input connectors
  • 500 watts RMS, 1,000 watts program power handling
294-326
Weight: 8 lbs.
IN STOCK
List Price$185.99
You Save20%
$148.79
Peavey Baseball Cap
Qty: 1Part # 520-302
List Price:$19.99
Part # 294-326
These cabinet-ready passive 3-way crossover networks are pre-engineered to provide all the frequency division and driver protection that you could need for your speaker system. The networks are designed to be used with 8 ohm speaker components, provide CD horn compensation, and feature SoundGuard™ overload protection on mid and high frequency drivers. The 12 dB/octave crossover frequencies of the ECS-3X are 500 Hz and 2500 Hz. The optimum low frequency driver type would be a professional 15" model, although heavy-duty 12" speakers can also be used. The intended mid speaker type would be a 6" to 10" direct radiator, open or closed back. If the mid speaker is an open back type, some sort of rear enclosure must be used to prevent interaction with the LF driver. The recommended HF driver would have a 1.4" to 4" diaphragm and be mounted on a constant directivity horn. Full range inputs are by 1/4" and Neutrik Speakon® connectors, and biamp inputs are through a unique Speakon switching connector. A 1/4" jack is used for the high- pass output which connects to the mid/high speakers. Peavey item 03490170.
Specifications: • Power handling is 500 watts RMS, 1,000 watts program • Dimensions of crossover component board: 10.25" H x 10.00" W x 4.00" D.
  • Crossover Type3-Way
  • ConfigurationIncludes Connector Dish
  • BrandPeavey
  • ModelECS-3X
  • Part Number294-326
  • UPC0014367088908
  • Product CategoryAssembled Passive Crossovers
  • Weight8 lbs.
View similar products to the Peavey ECS-3X PA Cabinet Speaker Crossover 500/2500 Hz 3-Way
in the Assembled Passive Crossovers product category.
can this be used as a replacement in a Peavey 3020-HT
Asked by: DonQ
The Peavey 3020HT- has crossover points at 400Hz and 2200Hz at 4 ohms. The Peavey ECS-3X is 500/2500Hz.
Answered by: TomI
Date published: 2014-12-23
Can this crossover be used with a 3- 4" diaphragm 180 degree horn? My speakers are old Altec Voice of the Theater Towers
Asked by: P Poreda
As long as the impedance is 8 ohms and the crossover points are correct, this should be fine in that application.
Answered by: Chrisf
Date published: 2013-02-07
CAN I USE THIS CROSSOVER IN PEAVEY SP3 SPEAKERS?
Asked by: LIQUIDDREAM
The stock crossover has a higher low/mid crossover point (650 Hz) which usually means the midrange will not be safe crossing any lower than this. I would recommend contacting Peaveys parts department for a direct replacement.
Date published: 2012-10-12
  • 2015-04-25T09:07CST
  • loc_en_US, sid_294-326, PRD, sort_recentQuestionsFirst
Customer projects that include: Peavey ECS-3X PA Cabinet Speaker Crossover 500/2500 Hz 3-Way
