Peavey ECS-1000X PA Cabinet Speaker Crossover 1000 Hz 2-Way
Brand:|Model: ECS-1000X|Part # 294-325
These cabinet-ready passive 2-way crossover networks are pre-engineered to provide all the frequency division and driver protection that you could need for your speaker system.
  • Ready to mount in your enclosure
  • CD horn compensation
  • SoundGuard™ overload protection on high frequency drivers
  • 1000 Hz 12 dB/octave crossover frequency
  • 1/4" and Neutrik Speakon® input connectors
  • 500 watts RMS, 1,000 watts program power handling
These cabinet-ready passive 2-way crossover networks are pre-engineered to provide all the frequency division and driver protection that you could need for your speaker system. The networks are designed to be used with 8 ohm speaker components, provide CD horn compensation, and feature SoundGuard™ overload protection on mid or high frequency drivers. The 12 dB/octave crossover frequency of the ECS-1000X is 1000 Hz. The optimum low frequency driver type would be a professional 15" model, although heavy-duty 12" speakers can also be used. The recommended HF driver would have a 1.4" to 4" diaphragm and be mounted on a constant directivity horn. Full range inputs are by 1/4" and Neutrik Speakon® connectors, and biamp inputs are through a unique Speakon switching connector. A 1/4" jack is used for the high- pass output which connects to the mid/high speakers. Peavey item 03490190.
Specifications: • Power handling is 500 watts RMS, 1,000 watts program • Dimensions of crossover component board: 8.50" H x 7.88" W x 4.00" D.
  • Crossover Type2-Way
  • ConfigurationIncludes Connector Dish
  • BrandPeavey
  • ModelECS-1000X
  • Part Number294-325
  • UPC014367088922
  • Product CategoryAssembled Passive Crossovers
    (5 Reviews)
  • Weight2.9 lbs.
View similar products to the Peavey ECS-1000X PA Cabinet Speaker Crossover 1000 Hz 2-Way
in the Assembled Passive Crossovers product category.
