BONUS ITEM INCLUDED
248-8367_ALT_0
Peavey Digitool MX32 Digital Mixing & Routing System 16 Channel In/Out
Brand:|Model: Digitool MX 32|Part # 248-8367
The Digitool product line has the power and flexibility to perform loudspeaker management functions in addition to matrix mixing, room combining and other audio processing functions for installed and portable sound systems, and it's From Peavey, one of the most trusted brands in the industry.
ORDER TODAY
Ships in 7-10 Business Days
$2,500.00
Peavey Baseball Cap
Qty: 1Part # 520-302
List Price:$19.99
*Domestic US orders only
Part # 248-8367
  • 16 inputs and outputs
  • Robust digital signal processing
  • USB, RS-485, and Ethernet connectivity
  • Full-color LCD control panel
Each Digitool model features a full-color display screen, front navigation and editing controls, front panel input and output mute buttons and LED meters to simply configuration. They can also be configured using a Windows application via USB or Ethernet. The Digitool MX 32 features 16 mic/line inputs and 16 line outputs with 48V phantom power switchable on each input. Each input and output has a 5-segment LED meter, as well as a mute button. There are two stereo AES inputs, and 8 CV "control voltage" inputs that can be programmed as level and mute controls, as well as an RS-485 input for external control of level, mute and preset recall. The front-panel USB port can be used for quick for setup in the field, and there's also a rear-panel Ethernet port for configuration in permanent installations. The firmware can be field updated, and the unit is 100V to 240VAC 50/60 Hz compatible.
Processing functions include: full matrix routing with mute and level control at each cross-point; input and output filters including PEQ, hi-shelf, lo-shelf, hi-pass, all-pass and horn-EQ; crossover filters to fourth order, including Butterworth, Bessel and Linkwitz-riley alignments; delay of up to 2.5 seconds on each input and output with sample period resolution; gate and compressor on every input; compressor/limiter on every output; digitally controlled analog input and output level controls for maximum dynamic range; 4 audio-triggered, priority mute buses; automix capability; signal generator; copy/paste of input and output settings; and preset storage and recall (8 internal preset locations).
  • BrandPeavey
  • ModelDigitool MX 32
  • Part Number248-8367
  • UPC014367620511
  • Product CategorySpeaker Processors / Management Systems
  • Weight31 lbs.
View similar products to the Peavey Digitool MX32 Digital Mixing & Routing System 16 Channel In/Out
in the Speaker Processors / Management Systems product category.
