Peavey BWX SC-18 Neodymium 18" Woofer Speaker
Brand:|Model: BWX SC-18|Part # 294-3216
Peavey's 18" BWX Neo subwoofer features a Kevlar® impregnated cellulose cone. The aluminum ribbon wire voice coil is wound on a polyimide-impregnated fiberglass former with Nomex® stiffener and solderless diffusion welded OFHC copper leads.
  • Lightweight neodymium magnet structure
  • Kevlar® reinforced cone for increased strength
  • Die-cast aluminum frame
  • High power handling
  • Polyimide-impregnated fiberglass former with Nomex® stiffener
  • 4" diameter aluminum ribbon voice coil
  • Solderless diffusion welded OFHC copper leads
Peavey's 18" BWX Neo subwoofer features a Kevlar® impregnated cellulose cone. The aluminum ribbon wire voice coil is wound on a polyimide-impregnated fiberglass former with Nomex® stiffener and solderless diffusion welded OFHC copper leads. Peavey item 00560900.
  • Nominal Diameter18"
  • Power Handling (RMS)650 Watts
  • Power Handling (max)1300 Watts
  • Impedance8 ohms
  • Frequency Response25 to 500 Hz
  • Sensitivity97.5 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)39 Hz
  • DC Resistance (Re)5.1 ohms
  • Voice Coil Inductance (Le)0.32 mH
  • Mechanical Q (Qms)9.95
  • Electromagnetic Q (Qes)0.5
  • Total Q (Qts)0.47
  • Compliance Equivalent Volume (Vas)9.94 ft.³
  • Mechanical Compliance of Suspension (Cms)0.13 mm/N
  • BL Product (BL)17.77 Tm
  • Diaphragm Mass Inc. Airload (Mms)122.6g
  • Maximum Linear Excursion (Xmax)2 mm
  • Surface Area of Cone (Sd)1240 cm²
  • Cone MaterialPaper / Kevlar
  • Voice Coil Wire MaterialAluminum
  • Magnet MaterialNeodymium
  • # Mounting Holes8
  • Sealed Volume5 ft.³
  • Sealed F366 Hz
  • Vented Volume14.18 ft.³
  • Vented F334 Hz
  • BrandPeavey
  • ModelBWX SC-18
  • Part Number294-3216
  • UPC0014367136753
    (2 Reviews)
  • Weight17.85 lbs.
B&C 15HPL76 15" Neodymium Woofer
Part #  294-682
B&C 15PS100 15" Woofer
Part #  294-673
View similar products to the Peavey BWX SC-18 Neodymium 18" Woofer Speaker
